Calendar/iCal alarms not going off
For some reason, alarms on Calendar events are not going off on my iMac running Tahoe 26.7.1 (and never sounded under all previous Tahoe versions, either)
In Notifications in System Settings, everything is enabled for Calendar. Can anyone please tell me what’s going on?
Things were so much smoother under Mojave…
I experienced the same issue when I moved from Mojave to a new iMac earlier this year. I moved all the events to the Reminders application, which worked except that every event persisted until it was deleted. Weirdly, then I was getting Calendar notifications again as well, so I removed them from the Calendar application. Then I deleted one or two of the events from Reminders and recreated them in Calendar. And notifications resumed. Now they’re all back in Calendar instead of Reminders.
Maybe something needed to get activated by Reminders (which I didn’t even know about, let alone ever use)?
That’s an interesting situation. Unfortunately, I don’t think Reminders will suit my needs. What I need to do is have an all-day event specified on a particular date, but have the reminder go off a week beforehand.
Reminders does not appear to be up to the task for that last part.
I guess maybe I’ll have to set up some dummy events in Reminders and see if I can trick Calendar into working, as you did?
Meanwhile, I tried Thunderbird’s built-in calendar, but it was horrendous. It has an in-app Reminder panel that will pop-up, but it doesn’t have the oomph that a full system notification would have. You can set a system notification to pop up, but the parameters are extremely limited.
If I can’t get Calendar working, does anyone have any third party Mac apps that might fill the bill? I don’t want to use cloud-centric options like Google Calendar.
Thanks!
BusyCal would work. Here is what the alarm settings are, fwiw
Thank you! I had forgotten about this! I always appreciate using a product with such a long heritage on the Mac. I used Now Up-to-Date more than 30 years ago.
BusyCal is great. I’ve been using it for longer than I care to remember to manage a multitude of repeating events, to-do’s and reminders across different calendars and with various date ranges and notification settings.
If I’m not mistaken, TouchBASE led to Now Up-toDate which led to BusyCal. So at least a theoretical/conceptional link to OS 9 (maybe even earlier, but OS 9 was when I started to use it). Anyway, a still-active development team is a good sign!
Along the lines of this discussion, Apple Reminders will let you set an event “Deadline” that is earlier than that event and that event/notification can be repeated.
Snapshot of the “custom” settings of a deadline:
I haven’t tried “Early Reminder” but that may be worth exploring.
While I never used TouchBASE, I can confirm that Now Up-to-Date goes as far back as System 7. I used it on a PowerBook 145 back in 1994, running System 7.1.
Wow, this thread brings back memories with the mention of Now Contact and Now Up-To-Date. I owned Now Utilities back in the System 7 and 8 days - and used the other utilities in the collection more than the contact and calendar options.
It’s sad to think of all the creative, useful utilities for the Mac that have gone away due to the OS being so damned locked-down.
Hi,
I use Alarmed, a port from iPh that works perfectly AFAIK.
I too have problems with Calendar- some items I can create both Events and Reminders, but sometimes only Events. DO NOT understand why.
Reminders (Mac)
I lost my previous (Chinese sw) iPhone Shopping List cataloguer and their replacement was riddled with traps and trackers I found out- so dumped it last year.
Ergo I had to adopt Reminders on iPh (OS 26x) and was pleasantly surprised it worked well enough. So matching with MacBook (also OS 26x) was a no brainer.
Alarmed will import from Reminders luckily, so anything timed gets added to it most of the time. Sometimes I have to go to Settings and manually import- either from the iPh or MB. A much lesser big deal than other options IMO.
Go to AppStore and you will find I’m the only person on the planet who’s left a Review on it. Give 5/5 and IIRC I’ve added donations in the last 10 years as well. Whatever the cost it is reliable and miraculously still works on Silicon Macs.
As a note- I also used Now Utilities way back when- not sure when or why I stopped but yes they were very effective for the time,
regards dave
