Originally published at: What a Broken Wrist Taught Me About iOS 27 Dictation and macOS Voice Control - TidBITS
There is a saying in the disability world that we are all only temporarily able-bodied. No matter who you are, no matter how healthy or capable you are now, there will come a time when you will need the kinds of accommodations that disability advocates have fought for over the years. Whether it’s due to genetics, accident, or inevitable aging, we will all have problems with vision, hearing, mobility, and motor control. Here’s my story.
On 12 September 2026, I started a planned 45-mile ride on my ElliptiGO when, just 0.5 miles in, I crashed on a flat, smooth suburban road with no traffic. I have no recollection of what caused me to go down, but I hit the left side of my head, cracking my helmet, strained muscles in my left hand, fractured the scaphoid bone in my right wrist, and picked up discrete points of road rash on my left ankle, knee, hip, chest, and elbow, plus all down the center of my face: forehead, nose, upper lip, and chin. At least I didn’t damage the tooth implants in three of my front teeth, which had been installed two days earlier after a 19-month process following a February 2025 ice skating accident (on the otherwise fabulous Rideau Canal Skateway in Ottawa).
Some passersby helped me immediately, and good friends who lived around the corner came and got me while Tonya was en route from home. Once she arrived, she took me to the ER, where a CT scan showed no problems (apart from the usual bats in the belfry), but X-rays revealed the broken wrist bone—luckily, a non-displaced fracture of the distal pole of the scaphoid bone, which is apparently the most common and heals quickly and successfully. They cleaned me up and sent me home.
Since then, although the road rash was ultimately minor, if a little visually shocking for a few days, I’ve had quite a lot of pain when using my left hand, and the right hand has either been in a temporary brace (which I was told not to take off but which was extremely painful, cutting off most sensation in my thumb) or in a (much more comfortable) cast. My ability to grip and lift objects has been severely curtailed, leading to exciting new explorations in personal care and marital patience! Unsurprisingly, due to the head trauma (the ER doctor never used the word concussion), I have been quite fatigued and spending a lot of the day in bed, resting, listening to an audiobook, or reading a book, depending on what I feel up to.
Needless to say, I haven’t been nearly as productive work-wise as I normally am. Happily, Glenn Fleishman contributed an article right away, and I have been able to get some work done using iOS 27’s dictation and macOS 27’s Golden Gate Voice Control. And that has provided a whole world of interesting results.
iOS 27 Dictation Now Supports Text Editing
The most useful discovery is that Apple has significantly improved dictation in iOS 27 by adding a few capabilities for editing text from the Voice Control system. In other words, Apple has finally done some of the things I requested in “How iOS and macOS Dictation Can Learn from Voice Control’s Dictation” (31 August 2020). Remember, dictation is what you get when you tap the microphone button on the keyboard, while Voice Control is an all-encompassing system that you turn on in Settings > Accessibility > Voice Control. The problem with leaving Voice Control on permanently is that it’s constantly listening and thus inserting text when you don’t want that, and at times I have felt that its dictation isn’t as good.
Most notably, when you’re using iOS’s regular dictation, you can now change the case of words and phrases by saying “Capitalize phrase” or “Lowercase phrase.” Incorrect capitalization of words drives me up the wall. Equally useful is the ability to fix misheard or misspoken words by saying “Replace phrase1 with phrase2.” Most other Voice Control commands aren’t available in dictation, but you can say “Select phrase” and “Undo that.”
So if you use dictation in Messages a lot, as I do, I strongly encourage you to update iOS 27 and start practicing with the capitalization and replacement commands. They are really useful.
Relying on macOS 27 Voice Control
Unfortunately, while Apple added some of Voice Control’s capabilities to dictation in iOS 27, it didn’t extend that effort to macOS 27 Golden Gate. Put simply, when you use dictation in macOS, you don’t have access to any text-editing commands.
Once I came to that sad realization, I turned on Voice Control in System Settings > Accessibility > Voice Control, and I have been doing pretty much everything on my Mac through Voice Control’s dictation since then. I have no trouble using my MacBook Pro’s trackpad for basic mousing and clicking (dragging long distances is hard; I’m experimenting with Drag Lock), and I can press individual keys on the keyboard, but I can’t type comfortably or accurately because of the pain in my left hand and my right hand’s restricted motion from the cast.
Overall, Voice Control dictation has worked extremely well, thanks in large part to Grammarly (see “Why Grammarly Beats Apple’s Writing Tools for Serious Writers,” 30 January 2025). Although macOS often recognizes words incorrectly, such as the original “enlarge” in the previous sentence, Grammarly does an excellent job of figuring out what I intended to say and offering a correction for either just the word (left) or for multiple words in the sentence (right).
You might wonder why I don’t use one of the many AI-powered dictation apps. The simple reason is that they all require you to talk for a while, then transcribe and process the audio before pasting the text back into wherever you’re writing. Even though it’s quick, it doesn’t work for me because I don’t know what I’m going to say until I have seen what I’ve already said, even as I’m writing a sentence. Plus, I frequently go back and tweak wording in sentences I’ve just written—I need word-level dictation for editing. For instance, when writing that last clause, I started with “per-word dictation” but decided I didn’t like it as soon as I saw it and added “for editing” after the fact.
That doesn’t mean Voice Control’s dictation is ideal. It frequently confuses plurals and possessives, not to mention homonyms; it can’t quote text to save its life; it is seemingly incapable of entering an em dash instead of an en dash; and even though I can add special words to its vocabulary, it often fails to recognize them, such that I regularly get “elliptical” instead of the desired “ElliptiGO.” Grammarly can fix only so many of these mistakes.
More annoyingly, Voice Control doesn’t work reliably across all apps. For instance, I can’t get it to capitalize a specific word in Slack, although I can select some text and say “Capitalize that.” It also can’t replace text in Slack. Quite a few other apps suffer from the same limitations.
The absolute worst, however, is Google Docs. No matter what Web browser I use, it insists on capitalizing words I say after a brief pause, presumably thinking I mean to start a new sentence. Plus, it often stops putting in spaces between words for no apparent reason. Google Docs actually has its own internal Voice Typing mode, but in my quick testing, it’s horrible. It also capitalizes words willy-nilly, and worse, I have to keep clicking the microphone button or pressing its keyboard shortcut to activate it—there’s no way to keep it on while in a document.
Finally, the other problem with Voice Control is that it’s always listening. If Tonya comes into the room and starts talking to me, it picks up her voice, and if I don’t realize it in time and stop Voice Control from listening, it picks up my responses too. We end up with entire conversations in my documents, which makes for surreal reading and extra editing later. Similarly, if I need to do something on the iPhone and use dictation there, it also puts the same words in whatever document is open on the Mac. Voice Control has functional “Stop Listening” and “Start Listening” commands, but I haven’t internalized them yet. I have some ideas for how to solve this problem that I’ll share more about later.
In the meantime, TidBITS may not be quite its usual self for a while until I’m feeling better. I hope things will be back to normal soon, although research suggests I’ll be in the cast for at least 6 weeks.
