The Real System Requirements for OS 27
Originally published at: The Real System Requirements for OS 27 - TidBITS
Apple has released public betas of macOS 27 Golden Gate, iOS 27, iPadOS 27, watchOS 27, and tvOS 27, along with a developer beta of visionOS 27 (see “Apple Opens Public Betas for OS 27,” 20 July 2026). We expect final releases in September or October. Many people are eager to learn whether their current hardware will support the new operating systems or if they’ll need to consider upgrading to stay current.
This year marks a significant shift: Apple has dropped all Intel-based Macs, completing its transition to Apple silicon across the Mac lineup. iPadOS 27 and watchOS 27 each drop five models, but iOS 27 will run on the same models as iOS 26.
Apple Intelligence Requirements
The primary software requirement that remains is Apple Intelligence, which requires an iPhone 15 Pro, iPhone 15 Pro Max, iPhone 16 models, iPad mini (A17 Pro), and iPad and Mac models equipped with an M-series chip, plus the A18 Pro-powered MacBook Neo. All watchOS 27-capable Apple Watch models are compatible with Apple Intelligence when paired with an Apple Intelligence-capable iPhone. Several additional tiers have also emerged:
  • Customizable Siri expressivity: To customize the expressivity and pace of Siri’s voice, you’ll need an iPhone 17 Pro, iPhone 17 Pro Max, or iPhone Air; iPad models with M4 and later and at least 12 GB of unified memory, Mac models with M3 and later and at least 12 GB of unified memory; or the M5 version of the Apple Vision Pro.
  • Improved Dictation accuracy: This on-device model requires an iPhone 17 Pro, iPhone 17 Pro Max, or iPhone Air; iPad models with M4 and later and at least 12 GB of unified memory; and Mac models with M3 and later and at least 12 GB of unified memory.
Determining precisely which features rely on Apple Intelligence is becoming difficult, but if you want Apple Intelligence capabilities, you’ve probably already upgraded.
macOS 27 Golden Gate Requirements
The Intel era has officially ended. macOS 27 Golden Gate runs exclusively on Macs with Apple silicon—no Intel-based Macs are supported. This completes the Apple silicon transition that began with the M1 chip in 2020 (see “Apple M1 Chip Powers New MacBook Air, MacBook Pro, and Mac mini,” 10 November 2020). If you’re still using an Intel-based Mac, macOS 26 Tahoe will continue to receive security updates for 2 years, meaning it will lose security viability in mid-2028.
macOS 27 will also be the last version of macOS to include the full Rosetta 2 translation environment. After macOS 27, Apple will retain only limited Rosetta functionality to support older games. If you rely on Intel-based apps, now is the time to find native Apple silicon alternatives.
macOS 27 Rosetta note
Here is the list of Macs that can run macOS 27:
Mac Chip and Model Years
MacBook Neo A18 Pro (2026)
MacBook Air M1, M2, M3, M4, M5 (2020 and later)
MacBook Pro M1, M2, M3, M4, M5, plus Pro and Max variants (2020 and later)
iMac M1, M3, M4 (2021 and later)
Mac mini M1, M2, M2 Pro, M4, M4 Pro (2020 and later)
Mac Pro M2 Ultra (2023)
Mac Studio M1 Max, M1 Ultra, M2 Max, M2 Ultra, M3 Ultra, M4 Max (2022 and later)
This means Apple has dropped support for the four remaining Intel-based Macs capable of running Tahoe:
  • Mac Pro (2019)
  • MacBook Pro 16-inch (2019)
  • MacBook Pro 13-inch with four Thunderbolt 3 ports (2020)
  • iMac 27-inch (2020)
iOS 27 Requirements
Impressively, iOS 27 maintains the same compatibility list as iOS 26, with the iPhone 11 from 2019 as the oldest supported model. Here are the compatible devices:
iPhone Introduced Chip
iPhone 17/17 Pro/Pro Max/17e 2025, 2026 A19/A19 Pro
iPhone Air 2025 A19 Pro
iPhone 16/Plus/Pro/Pro Max/16e 2024, 2025 A18/A18 Pro
iPhone 15/Plus/Pro/Pro Max 2023 A16 Bionic/A17 Pro
iPhone 14/Plus/Pro/Pro Max 2022 A15 Bionic/A16 Bionic
iPhone 13/mini/Pro/Pro Max 2021 A15 Bionic
iPhone 12/mini/Pro/Pro Max 2020 A14 Bionic
iPhone 11/Pro/Pro Max 2019 A13 Bionic
iPhone SE (2nd–3rd generation) 2020, 2022 A13 Bionic/A15 Bionic
iPadOS 27 Requirements
While the iPhone compatibility matrix remains the same, Apple dropped five iPad models from the list of those that can run iPadOS 27, leaving this complicated set:
iPad Introduced Chip
iPad Pro (M4 and later) 2024, 2025 M4, M5
iPad Pro 12.9-inch (4th–6th generation) 2020, 2021, 2022 A12Z Bionic, M1, M2
iPad Pro 11-inch (2nd–4th generation) 2020, 2021, 2022 A12Z Bionic, M1, M2
iPad Air 11-inch/13-inch (M2, M3, M4) 2024, 2025, 2026 M2, M3, M4
iPad Air (4th–5th generation) 2020, 2022 A14 Bionic, M1
iPad (A16) 2025 A16
iPad (9th–10th generation) 2021, 2022 A13 Bionic, A14 Bionic
iPad mini (A17 Pro) 2024 A17 Pro
iPad mini (6th generation) 2021 A15 Bionic
The models dropped from iPadOS 27 include:
  • iPad Pro 12.9-inch (3rd generation, 2018) with A12X Bionic
  • iPad Pro 11-inch (1st generation, 2018) with A12X Bionic
  • iPad Air (3rd generation, 2019) with A12 Bionic
  • iPad (8th generation, 2020) with A12 Bionic
  • iPad mini (5th generation, 2019) with A12 Bionic
watchOS 27 Requirements
Where watchOS 26 maintained compatibility with everything supported by the previous watchOS 11, watchOS 27 is a major break, dropping support for five older Apple Watch models and making the Apple Watch Series 9 the oldest supported model. The current supported models are:
Apple Watch Introduced
Apple Watch Ultra 3 2025
Apple Watch Ultra 2 2023
Apple Watch Series 11 2025
Apple Watch Series 10 2024
Apple Watch Series 9 2023
Apple Watch SE (3rd generation) 2025
That means Apple has dropped support for:
  • Apple Watch Series 6 (2020), 7 (2021), and 8 (2022)
  • Apple Watch Ultra (1st generation, 2022)
  • Apple Watch SE (2nd generation, 2022)
tvOS 27 Requirements
Although Apple doesn’t have a tvOS 27 page laying out compatible devices, 9to5Mac quoted a developer as saying that tvOS 27 drops support for the two oldest previously supported Apple TV models, leaving:
Apple TV Introduced Chip
Apple TV 4K (3rd generation) 2022 A15 Bionic
Apple TV 4K (2nd generation) 2021 A12 Bionic
That suggests that tvOS 27 won’t support the original Apple TV HD from 2015 (formerly known as the 4th-generation Apple TV) or the Apple TV 4K (1st generation) from 2017.
tvOS 26 also had an additional specific requirement that we suspect carries over: Apple Music Sing requires an Apple TV 4K (3rd generation) or later.
visionOS 27 Requirements
Although Apple replaced the original M2 Vision Pro with an M5 version in October 2025, visionOS 27 works on both (see “New M5 Chip Accelerates the MacBook Pro, iPad Pro, and Vision Pro,” 15 October 2025). The only difference is that the option to customize Siri’s voice expressivity is available only on the M5 version.
HomePod Software 27 Requirements
Apple provided no updates regarding HomePod compatibility at WWDC, but since the public betas of HomePod Software 27 support all existing HomePods, it’s a safe bet that this will continue.
Still waiting for Garmin to introduce Apple Silicon versions of their software.
Thanks, Adam, for the write-up. I’ve no interest in Apple Intelligence, so that part gets a shrug from me. I’m not hugely surprised that both my M3 MacBook Air and 2022 iPhone SE will be compatible, either. I no longer have an iPad, but will bare in mind if I do decide to get another one.
Regarding Intel-only apps, I’m currently down to just three:
  • The Mac version of Brainwave Studio — the iOS version mostly works on my MacBook Air, but both are abandonware so I suspect that won’t last forever.
  • Hemingway Editor 3 — the developers of this have moved to online AI-driven version, which is a shame as this is a genuinely useful app for editing my writing.
  • Adobe Digital Editions — I only have this for transferring Kobo ebooks and converting them to PDF using Calibre, but I should now be able to do that entirely within Calibre in future. Honestly, I will be glad to see the back of ADE, as apparently are Adobe who’ve stopped developing it.
I am still on macOS Sequoia and iOS 18 for now, and hoping that the '27 updates are more palatable that their '26 predecessors. :crossed_fingers:
Disappointed that our Intel Macs will soon be forced by security concerns to run MacOS 26 rather than the version with UI bug fixes.
Excellent summary Adam, thank you! Overall, the biggest loser is the one that bought the first gen Apple Watch Ultra from 2022…
I don’t think it will be so bad. Beyond Siri AI, there don’t seem to be many features added or changed all that much in watchOS 27, and the original Ultra already didn’t support double-tap or on-board Siri requests, so single-tap wouldn’t be supported anyway. watchOS 26 should be fine for the next year.
As a long-time Apple watch user, I’ve come to find that a watch needs to be upgraded every three years just for battery reasons, so the last people who bought the Ultra while it was still being sold by Apple should be hitting three years in September anyway.
The Sonos app for Mac as well is still Intel, weirdly. The iPad version of the app doesn’t seem to be allowed in the Mac App Store. Thankfully I can use the web app if they never update it.
Thanks for the extensive overview! Good to know most of my devices will be able to run 27. I am planning to upgrade (eventually) to 27 having skipped 26 so far. My Apple TV HD won’t be upgradable to 27, but if that becomes an issue and installing 26 doesn’t resolve that I can get a new Apple TV 4K.
The thing that I am wondering about is my Apple Watch 6 which won’t run 27 while my iPhone 12 mini will. What happens when my phone is upgraded to 27 but my watch remains on 11.6.2 (or maybe is upgraded to 26)? Will the watch still work or would I need to get a new one? And if I get a new watch, will it work with my iPhone 12 mini? Does anyone know how different versions of phones and watches work together?
The watch will work. All watches must be paired with an iPhone that is the same major release or higher. So a watch with watchOS 27 will not work with iOS 26 or lower, but a watch with watchOS 11 will work with any iPhone iOS 18 or later.
Forced? Not sure that is the case. One could continue to run the OS that now runs on the Intel Mac. No loss of functionality. If worried about Apple’s vague security blather, then limit the internet connectivity, and as with any digital device be conscious of physical security.
I have at 7 older Macs in the house that work fine on older OSes. They don’t do much on the internet but they don’t need to.
My fear is Rosetta going away (not until macOS 28, and not completely) is that Wine will stop working for running Windows apps. I have a bit of Windows-only software that I don’t rely on, but would prefer to be able to use.
Also Brother multi-function laser printer software still has some intel components, But there is hope they will finally deal with that. Their software is not required for printing, nor for using Image Capture to scan (at least for recent models, which support AirPrint). But their software does seem to be required to allow pushing a button on the printer to initiate a scan to the computer (not that I have found that to be reliable, alas).
