Retrobatch 2.3.1
Originally published at: Retrobatch 2.3.1 - TidBITS
Flying Meat has released Retrobatch 2.3.1, which includes an update to the Delete Metadata node. This operation now re-encodes TIFF and PNG images, which is necessary to delete all metadata from these files (JPEG images are not affected). The bulk image processing utility also updates its Get Selected Finder Images node to check with the Finder every 10 seconds, addresses a problem where the Dither filter wouldn’t work correctly with gray profile images, fixes a bug that prevented the app from properly cleaning up disk files when converting to JPEG-XL, and resolves an issue where “Keep original and modified dates” wouldn’t work if you had the “Write back to original images” option enabled. ($29.99/$49.99 new with a 20% discount on new purchases for TidBITS members, free update, 58.7 MB, release notes, macOS 12+)
