I’d really like to finally sort this out but not exactly sure how or if it’s possible without de-selecting Tap-to-click.
It seems that my closely hovering palms have an effect of engaging the track pad so when I am typing a sentence the cursor wanders, rapidly, to all sort of different areas on the “page”
Often times I find that I have written many lines that have been inserted in all sorts of different places
thoughts please … should I be wearing an antistatic wrist band!!! lol
I see this all the time. It’s a side effect of resting your wrist/palm on the keyboard. Not good touch-typing form, but something most people do. When the trackpad is big, you end up touching it, causing these problems.
Some trackpads (like ones I often see on PC laptops) have “wrist rejection” logic that you can enable via its settings apps. For me, however, that’s not sufficient - it helps, but it’s not enough.
I’ve found that for this reason, I always disable all tap gestures on my trackpads. If I have to actually apply pressure (or use an external button, on those trackpads that have separate buttons), then the random clicks don’t happen. The cursor still moves around, but it won’t cause my input focus to change.
