X(Twitter) page misbehaves in Safari 26.2 and 26.3
I (almost) always keep X(Twitter) home page open, as a tab in Safari window. It used to have no problem at all, until Safari 26.1.
On December 13, 2025, I updated my M4 Mac mini (24 GB RAM installed) to macOS 26.2, so Safari was updated to version 26.2. Since then, the X(Twitter) tab started to misbehave frequently.
The symptom: If another tab is opened over the Twitter tab (that is, if the Twitter tab is put to the background) and I work on the other tab for a while (especially do something that involves video playback), then, when I select the Twitter tab to bring it back to the foreground, the Twitter tab frequently comes up empty. (that is, the tab’s page content is fully white - nothing is drawn there.)
Pressing Command-R (Redraw page) does not change the situation, but if I click the “Twitter” item on the Bookmark (Favorites) Bar, the tab does go back to normal, fixing the problem.
I tried Emptying Cash (Command-Option-E) and relaunched Safari, but that didn’t fix the situation.
Sometimes (but very rarely), a chunk of text is drawn at the top-left corner of the tab page, saying:
“Too much electricity consumption caused this Web page to be redrawn.” (or something, in Japanese)
but actually the page was not redrawn: the tab page is empty, other than the one-line text.
The situation remains the same, after I installed macOS 26.3/Safari 26.3, until now. What can I do to avoid the empty Twitter page, without needing to hit the bookmark each time?
As far as I can tell, there is no way to stop Safari in macOS from shutting down resources to a background tab that is using too much energy (other than being always plugged in maybe?)
One thing you could try is to pin the tab - maybe Safari is more liberal with pinned tabs? But I’m not sure that this will matter.
If that doesn’t work, I might consider using twitter with another browser? Or simply quitting and re-opening Safari, which should reopen all existing tabs? On an apple silicon Mac this has always been fast for me. I used to do this a lot when the 1Password extension stopped working right in Safari, but thankfully that issue seems to have improved lately.
Thanks, Doug, for your ideas.
I tried that, but it didn’t work. The problem still remained.
Selecting the Twitter bookmark on the Favorites Bar (or just Command-Option-4, because it is the 4th item on my Favorites Bar) on the blank tab page (that’s the working method) is easier then quitting and re-opening Safari (Command-Q and then Control-Option-Command-S), isn’t it?
(Control-Option-Command-S is my Keyboard Maestro shortcut for launching Safari.)
energy
Is there any way to downgrade Safari-only, that is, (somehow obtain and) install Safari 26.1 over macOS 26.3? (Safari 26.1 on macOS 26.1 never had this problem.)
I am glad to report that this problem seems to have been fixed in Safari 26.4.
The problem had never occurred in Safari 26.1 and earlier. In Safari 26.2, 26.3, 26.3.1, the problem occurred frequently. – If I put the Twitter tab to the background by opening another tab, work in that tab for a while, and then click the Twitter tab to bring it to the foreground, then the Twitter tab page is empty (plain white), nothing is drawn there. I need to click the Twitter bookmark (on the Favorites bar) to bring it back - the purpose of “tab” is lost.
I’ve reported the problem to Apple Support (on Feb 20th.)
Now, this week, I updated to macOS 26.4 (and Safari 26.4) and the problem went away. Safari has never shown the empty Twitter tab for 4 days now. No problem anymore!
So, it seems that Apple has fixed the problem in Safari 26.4.
