Floodtide: a MacUpdater replacement, now with Import from MacUpdater
I’m the developer of Floodtide, a Mac app updater I started building when MacUpdater was discontinued. Its update server is due to stop at the end of December, so if you still rely on it, now is a good time to try the alternatives. Here’s where Floodtide is today.
What it does: it scans the apps you already have and checks each one against wherever its developer actually publishes updates. That covers Sparkle feeds, Homebrew casks, GitHub releases, Electron update feeds, Microsoft AutoUpdate, Google’s updater and the Mac App Store, plus a hand-researched list of about 2,000 apps that publish versions somewhere awkward. Then Update All installs them together.
A few things I care about:
  • Before it replaces anything, the download has to be the same app (bundle ID), from the same developer (signing team), and pass Gatekeeper. If it can’t verify an app, it gives you a link to the developer’s page instead of guessing.
  • It keeps a copy of the old version, so a bad update is one click to undo.
  • Betas are off unless you turn them on, per app.
  • For each app you can see which sources it checked and what each one said, so it’s never a black box.
New for MacUpdater users: File > Import from MacUpdater reads your MacUpdater ignore list and exported app list, shows which of those apps Floodtide covers, and lets you request the ones it doesn’t. There are also keyboard shortcuts that match MacUpdater’s (Cmd-L to open an app, Cmd-S to show it in Finder and so on).
It also handles Homebrew formulae, App Store updates, audio plug-ins and screen savers. It runs on macOS 13 or later, Intel and Apple silicon, in English, German and Spanish.
Pricing: a 14-day full trial with no account or card. After that, scanning stays free, and installing updates needs a one-time licence: $14.99 / £10.99 / €12.99 for 3 Macs. There’s also an optional yearly add-on (the Tide) for newly researched apps; you don’t need it for anything above.
I’m happy to answer questions here. And if it misses an app you use, tell me which one; that’s how the list grows.
It’s looking nice. I’d like to see:
1. Download Only Option
I’d like this to download all of the updates and verify the app is notarized and the Developer ID matches without installing the updates. For any app that fails those checks, the user should be informed and given the option to keep or remove the downloaded file. The user should be able to specify the download location.
There are several reason why I would use that option, including: (1) I maintain an archive of the apps/setup files (.dmg, .pkg, .zip) for all of the apps I install, (2) I often download a new version of an app but wait a bit to install it to make sure there aren’t any problems with the new version (and some developers only distribute the current version and don’t provide an option to download older versions), and (3) for security reasons I have never, and will never, allow any app to install/manage other apps on my Mac.
2. VirusTotal Scanning (via user-provided API key)
Regardless of whether a user choose the “update” or the “download only” option, it would be great if Floodtide could check VirusTotal and provide the option to submit any update file that hasn’t already been scanned by VirusTotal. The user would be expected to supply their own API key.
Rafael, thank you for Floodtide – it does its job neatly!
And you’re updating it almost daily at present – extraordinary!
