My Downloads folder lives in my dock; clicking it opens as a fan. When the fan is open, I can drag a file directly from it to the Trash, and that’s where it ends up. But if I drag a folder, although it seems to work, the folder doesn’t get moved to the Trash.
I’m hitting another weird Dock icon behavior in Golden Gate 27.2. This is 100% reproducible:
In the Finder, create a new folder.
In the Finder, option-drag a file to the new folder from another folder.
In the Finder, rename the newly copied file
In Safari, click a link that downloads a file to my Downloads folder
In the Dock, click on my Downloads folder. The Dock expands the Downloads folder as a Fan (or maybe Stack)
Drag the downloaded file to the folder created in step 1.
The expected result is that it will move the downloaded file to the folder. The actual result is it will move the file that was copied in step 2!
But other times I can drag a file from Dock > Downloads to a folder, and it works as expected. It just moves the wrong file when I do the above sequence of steps, every time.
Normally reporting problems to Apple is futile, because I’m always at least one release behind. It will be a new experience to be able to report a problem that they may actually look at. But, what will happen is they’ll ask me to install and test it in the latest Golden Gate beta. No chance I’ll do that.
I can clearly see the behavior @jbr is reporting on the video. However, as @josehill reported, I don’t see it on my computer either. MBP M5 Pro, macOS 27.2.1.
I cannot recreate this behavior on my other MBA (an M5*) running 27.2.1. Dragging the downloaded file from the fan to the folder moves that downloaded file, just as you would expect.
* - the M2 is at my summer house, the M5 is at my primary home; I was at the summer place this morning to meet a contractor when I posted my first message, then came home and saw this one.
