I’m in the market for a 75" smart TV and keep going back and forth on whether the built-in smart platform even matters if I plan to plug in an Apple TV box anyway. I came across this comparison page while looking at options: Best 75" Smart TV of 2026. What I’m unsure about is whether the ranking criteria (picture quality, gaming features, etc.) are worth weighing heavily when I already have an Apple TV 4K for streaming, or whether I should just focus on panel quality and treat the smart OS as a bonus I’ll bypass. I’m also curious how people here handle things like input switching and volume control in a mixed Apple TV + TV remote setup. Has anyone bought a 75" recently and wish they’d prioritized one thing over another?
I have a Samsung in that size range, but in terms of your criteria for a TV, I don’t think size matters. I am firmly in camp “dumb as a rock”. Mine has all sorts of internet-enabled bells and whistles that are and shall remain absolutely silent. I didn’t “set it up”, nor did I connect it to the Internet. I just plugged in my ATV 4K and that, plus the ATV remote, plus Siri on my HomePod give me everything I want in a TV. I’d definitely concentrate on picture quality and brand reputation if I were in your place.
Maybe I am biased after using Front Row on a Mac for many years then an Apple TV with a plain TV for several more but … I find the typical “Smart” TV user interface clunky and frustrating.
I was forced to buy a “smart” TV recently and, fortunately, the system starts up with the HDMI input that the ATV is connected to (i.e. it remembers the last input). But it still wastes time for the TV’s OS to load - maybe because I have denied it internet access.
The TV has ARC (?) and a compatible HDMI cable so it wakes when I power up/wake the ATV. Then I am good to go. The TV also goes to sleep when I power down the ATV.
The ATV Settings can learn the TV remote operations such as volume up/down and these work on the Siri Remote so I rarely need to use the TV remote. However in my case I use stereo Homepods for audio, controlled by the ATV.
I also avoid using the TV’s free-to-air function (and running an aerial cable to the TV) by using an HD Homerun TV tuner on my home network and the Channels app on the ATV. The Homerun device also serves iPhone and iPads over wifi so I can watch live TV in the kitchen (take that Homeview!).
I even take an HDMI cable and USB-c adapter when I travel so, where practIcal, I can override the hopeless hotel smart TV and use my iPad for video streaming and music.
Another tip: the Remote app on the Apple Watch can control many of the Apple TV functions. For example, the scroll wheel can change the volume. Saves strapping the AppleTV remote to my wrist ![]()
I have a slightly larger LG and LG Soundbar. The TV is not connected to the network. I fully control both using only the Apple TV remote.
If all your media streaming will be via an Apple TV, then the smart features are probably going to be pointless.
Don’t bother connecting the TV to your network at all. It won’t help, and it will enable the manufacturer to spy on you. LG was recently in the news over this.
If you can’t set up the TV without network connectivity, see if you can reset its network settings after setup is complete. To be extra safe (in case a reset doesn’t actually reset its connections) consider connecting an Ethernet wire during setup, so you can just unplug it afterward.
Definitely worth considering. Picture quality is important no matter what the source is. Color calibration can only go so far, and won’t make a low quality panel look as good as a high quality panel.
Gaming features typically mean reducing or eliminating image processing in order to reduce latency. Very important if you are going to play video games on the set. Meaningless if you’re only going to watch movies and TV shows.
This is the most annoying part. These smart TVs all run Linux or Android under the covers, so you need to wait for them to boot up when you turn them on. There are often “quick start” options, but that just means the processor never turns off when you power-off the set, so it wastes power (how much will depend on how well they designed it).
Compared to the old dumb TVs without actual computers in them, which would power-on in a second or two.
Definitely find the AppleTV 4K delivers all the smarts I want in a TV. Fully agree with Jeff, picture quality and build should be your concern.
Just to say it, you may find excellent value in your local second hand market. I recently picked up a large Panasonic gas plasma, the seller was all “I’m afraid it’s not smart…” I had been looking at OLEDs in four figures and I got this for just over 100. It may be nearly ten years old, HD rather than 4k, and only last another few years but it is a beautiful screen and I’m very happy with it.
I agree with those using an Apple TV and HomePod speakers to connect to a smart (or dumb) TV.
And combined with the HD HomeRun TV tuner (connected to router) gives two channels at once and multiple devices to watch free to air shows.
Just ignore the “smart tv” options in the set up, and control it all via ATV settings.
One button press on ATV remote turns on or off both tv and ATV.
My next upgrade will be to a modern AVR. I already have all my streaming apps installed and functioning on my Tizen OS TV (truly the worst of the lot). I’ll leave the TV as is as a backup (to when I get a ATV). The only question is using an ATV… and here I may very qwell go for a used older one… I had kinda planned to maybe go as high as 200 for the newer model, but 300 is a bridge way too far.
