Wired keyboard, M4 iMac
New M4 iMac 24” refurbished from Apple. MacOS 26.5.2 update. Wanted to use a full-size Apple A1243 wired keyboard. Attached it to one of the four USB ports on the iMac using an Apple USB-C to USB adapter. Upon restarting (and with the “Magic Keyboard” turned off) the iMac does not see the wired keyboard. It does see the wireless mouse. Many articles online say this should work. The iMac is Part No. G1K56LL/A SN:KX0R4KQW9M Model No. A3137 if that helps.
I do not want to buy a full-size wireless keyboard! But I do not like the small “Magic Keyboard” with no keypad.
It definitely should work. If it doesn’t, either the keyboard is bad, the adapter is bad, the port on the Mac is bad, or something isn’t fully plugged in.
It sounds silly, but I’ve done it a few times myself: make sure the keyboard cable is fully inserted into the USB adapter. Also, be sure to try the other USB ports on the Mac. Do you have any other wired devices you can try? Do you have any other computers you can try plugging the keyboard into?
This happened to me a few months ago with an M4 Mac mini and a USB-A cable (plugged in to a USB-A to USB-C converter) for a UPS. I had it plugged in to one of the Mac’s USB ports, the Mac could not communicate with the UPS, and plugging in to another USB port on the Mac fixed it.
I should have mentioned that sometimes the issue isn’t that a part is “bad,” but rather that the connector is dirty, preventing an effective contact.
If there is fuzz or other gunk on a connector, it can interfere with operation. If that’s the case, a plastic spudger or a plastic toothpick (including soft “interdental” picks) can help.
This happened to me, too. M4 Mac mini, wired Apple Extended Keyboard, connected via a USB-C to USB-A adapter. See the thread < New M4 Mac mini susceptible to low temperature? >.
In my case, the problem occurred very infrequently. My solution: use the mouse to switch to the ‘guest’ account, which doesn’t need a keyboard to log in. Then open Notes app and type some characters from the keyboard. If it works, then log out and switch to the regular user account.
I have heard that the cause might be the signal that recognize the keyboard at startup is so low-powered, and is sometimes missed. Wait for the Mac to warm up, and then restarting might work.
I’ve got also a refurb M4 on 26.5.2, and in setting it up I used a wired keyboard from our G3 iMac and an Anker usb a-c connector. Worked fine so I don’t see why your setup should not, after trying the other troubleshooting tips listed in this Topic.
If the keyboard works with other computers, and with the same adapter, then those parts should be ok and then one has to wonder what is up with the Mini. Try all the Mini’s ports, and with other devices as well. If other accessories work in all the Minis usb-c ports, hm, quite the head-scratcher. Try to anticipate how Apple would troubleshoot it if you sent it in for replacement and do those steps before time runs out to return/replace it.
When I was in training as an Apple Specialist way back, we were told refurbs could very well be more reliable than any random one off the assembly line, as every refurb went thru detailed QC before selling, but mass produced new items were only spot checked. Don’t know if that’s still (or even then was) true but I’ve personally bought various Apple refurbished items, maybe 4-6 over the years and they have all been reliable and even later had some trade in value at Apple on other purchases.
Thanks for suggestions. Tried a variety of things. Nothing worked until:
I attached an OWC Thunderbolt Go Dock to one of the iMac’s USB-C ports.
I plugged the Apple M1243 cable into the USB-A port on the dock.
Turned OFF the magic keyboard. Shut down the iMac. Restarted the iMac.
Note: wait a few seconds for a dot to appear in the password window.
Logged in – it appears the keyboard works perfectly.
So, problem (seems to be) solved – as long as I use the OWC dock.
Thanks everyone for the information.
Hi James. Sorry for my late reply. I know you have solved this but just in case this is handy to you, or someone else…
david_blanchard and I have also sometimes had problems with using an A1243 keyboard. See previous thread here: Wired USB-A keyboard issue. In my case, adding a USB extension cable resolved the issue. But david_blanchard needed to remove an extension cable to get it to work (!). There are other suggestions at the Stack Exchange question I linked to in that thread, including plugging a USB memory stick into the keyboard, to increase the current draw.
I bought an OWC Thunderbolt Go Dock in 2024 for use with an Intel MacBookPro.
A few weeks ago I bought a refurbished iMac 24" M4 from Apple.
I wanted to use a wired Apple Model A1243 keyboard instead of the small battery-powered “magic” keyboard.
Using an Anker USB C adapter, I plugged the keyboard into one of the iMac’s ports.
The iMac did not see the keyboard. I tried the other ports and different keyboards, same result.
I tried the dock and plugged the Anker adapter with the keyboard into one of the dock’s ports. This worked.
In order not to have the dock running all the time (it gets warm) I tried other keyboards.
I found that a Matias Aluminum keyboard (it looks identical to the Apple A1243) with the Anker adapter plugged in the iMac port worked well. Thus I do not need to leave the dock plugged in all the time.
Thank you for your reply. I am glad to know that the dock will not have a problem when I need to use it with the iMac M4.
Jim Pittman
