Rosetta 2 is going away 2027 — FileMaker Pro upgrade path?
Since Apple has now told us that they plan on starting to phase out Rosetta 2 with macOS 28 that means come 2027, we need to start getting serious about either VMs or Apple silicon native apps. For me that essentially boils down to FileMaker Pro 16. I have plenty of older Intel Macs I can play old games on (if I ever find the time), but it’s my own productivity apps, especially my own databases that I’ve been curating since the 90s that I need to worry about.
So, what in 2025 are the least expensive ways to get a native Apple silicon FileMaker Pro license if you’re purchasing not as a business, but as just a private citizen?
There’s been threads on updating older versions of FMP (like this or that) and even on developments toward a supposedly free FMP license, but all of that feels a bit stale by now. So what’s the lay of the land in 2025? Is it really $625 for FMP 2024 (or $374 for upgrading from FMP 16 or newer) or bust?
5 posts were split to a new topic: Avoiding the Photoshop Elements “subscription”
FileMaker is the first app I thought of when I heard the Rosetta 2 deprecation news.
The most cost effective solution is to convert from FileMaker to Microsoft Access, which does run on Arm using Microsoft’s version of Rosetta 2.
I’ve considered migrating from FileMaker to other products for a long time. Unfortunately, none are as easy to use. And I don’t think there is a mechanism to migrate a database to something else that will preserve binary object field data (I use embedded images in several of my databases) and multi-value fields.
So, assuming I can find a suitable replacement, migrating to it is going to require custom AppleScript work, since there doesn’t seem to be a way to just export/import the data.
Uh, I’d just keep going until 2027 and beyond until there’s some reason you absolutely need to upgrade. I bet you can get to 2030 before it’s a real issue.
Like Libre Office (as an alternative to MS Office) I guess we should look out for (hope for) an open access community that will develop software that will enable us to keep using and working on “old” FMP databases.
Regarding MS Access, my disgust for that product was one of the reasons I moved to Mac and FMP:
https://www.vdrsyd.com/aoaug/ms_dig.html#access2
Depends on what version you’ve got today. According to Wikipedia, Apple Silicon support was introduced in version 19.3.2 (July 2021). If you’ve got an installation of 18 or older, then it will break when Rosetta goes away.
It’s been a long time since I worked with Access, but the last time I looked, it is a GUI wrapper around an SQL engine. Not (conceptually) any different any other SQL-based solution, including LibreOffice Base (which can connect to external open source database systems like MariaDB, MySQL or Postgress).
Without commenting on that specific solution, I will say that I’ve been delighted by the performance of Windows Intel apps running on my M1 MacBook Air via the ARM version of Windows 11 using Parallels workstation.
I have a moderately complex database running in a custom-coded, in-house application using that method, and it works extremely well.
Not if you don’t upgrade your OS to the Rosetta-less version. If you’re on an earlier version of FMP anyway, why do you need to upgrade to the most modern Mac OS? Just stay with what works until it becomes actually problematic in some way.
That’s great if you can dedicate one computer for each app. The rest of us don’t want to forgo all future system upgrades in order to avoid paying to upgrade one application.
Enough. We’re not going to debate if you upgrade or not. The premise of this specific thread is that FMP needs to be upgraded every once in a while to keep up with an evolving macOS. Anybody who doesn’t have FMP 19 or newer (as @shamino pointed out) needs to upgrade at the latest once Rosetta is no longer available. That is what my thread is about (since I still have FMP 16 I very much fall into that camp). If you don’t like it, that’s fine — you’re welcome to stay out and start your own thread. But don’t crap up this one.
“Stale” is a good description. I’d love to hear from anyone in the FMP inner circle who knows if this proposal is dead in the water, on the back burner, or “coming soon.” When it first came out, I was really hopeful.
Though it has been happening for years at these events, the sheer amount of ebullient adjectives was off putting.
I don’t think there’s a simple solution other than what you’re doing - keeping an old machine to run it.
When FMP 19 came out I bit the bullet and updated from FMP 17 as I was fearful I would be forced into a subscription. I have 19.6.3 happily running on my 2021 M1 Max MBP and have no intention of updating unless it breaks. I would NOT update if I was forced to a subscription - I’d rather retire my current machine to run FMP 19 and put the subscription money towards a new machine.
My only use of FMP now is for tracking my contract and rental income, business expenses and depreciation. It’s a reasonably complex solution which I wouldn’t like to rewrite from scratch with a database backend and XOJO or similar. It could be done - but the investment in time would be way more than the cost of an FMP license.
Being retired now I’d hoped the freemium version would arrive as I’m definitely a one man show with no need for networking or sharing. It would be a perfect solution for me but it’s now looking like vapourware.
Has anyone tried Panorama X as a FMP replacement?
It is my understanding that FMP 19 is still Intel. And only FMP 21 (or by some accounts 2021) is native Apple silicon (or Universal).
That’s a shame because FMP 19 can actually still be purchased for cheap ($149+$4 s/h) right now. If that is a legit offer (?), I guess it depends what kind of upgrade pricing is offered when the time comes. Right now upgrading FMP to 2024 is $374, making this not that much of a steal. However, that upgrade actually reaches as far back as FMP 16, which I own. So perhaps that’s not too bad of a deal right there.
19 is definitely universal:
Well, there you go, @Simon ! Buy the cheap version of FMP 19 that you noted and you’re good going forward.
I think it changed in the later FMP 19 builds. FMP 19.6.3 definitely shows as Universal.
Screenshot 2025-06-20 at 3.42.08 pm
Thank you, @trilo. That explains it then. While the vanilla 19.0 was indeed Intel (took that from the RoaringApps db), later 19.x updates must have brought it to Apple silicon as @shamino’s and your screen shots show. I’m assuming updates from 19.x to 19.6.3 are always free downloads — at least that’s the way it’s traditionally been with FMP.
That’s great news if indeed these $154 offers for FMP 19 are legit. I’ll be trying one at some point. Just too busy with other stuff right now.
