MOSDART USB-A / USB-C Dual Flash Drives
I love them untill finding out 5GBS was all I could get. So sending back to Amazon the 1TB drive and will look into others. I need the duality of USB-A and USB-C to share data with students and such. But can’t abide 5GBS. Looks like SanDisk and SSK makes them at 1000GBS speed. Patrick
Get whatever you like. And then just adapt. So if you want a 10 Gbps stick with USB-C, get it knowing it will work just fine on any 5 Gbps USB-A machine using one of these.
Quick update. I communicated w MOSDART yesterday and they are working on new drives that will be 10GBS. Not sure when available. Patrick
What did you end up getting instead?
Morning.
I am sending the 1 TB MOSDART back to Amazon cause is way too slow but will keep the 256 and 64GB drives.
I use Crucial X10 8TB portable to back up my MacbookPro and my StudioUltra as well as cloud space.
I bought previously a Hynix NVME 1TB and placed it in an enclosure and it is so fast, albeit larger.
I think SanDisk makes some 10GBS flash drives too.
Regards, Patrick
