As mentioned in this post, the display on my mom’s 2017 iMac died and was replaced (along with the logic board) by Apple. They only charged us for one of the two components. We’re both grateful, but I still don’t understand it. Does this mean the GPU got replaced as well, or is that yet another component?
This morning, she comes to me saying, “My computer is dead again!” She has her startup chime silenced, so it would appear to be dead from her perspective.
The first thing I do is have her plug in her external SuperDrive. The sound it makes at startup tells me that the computer is indeed receiving power. (Even if you no longer use optical media, that’s a great diagnostic tool!) She tells me she had tried holding in the power button already.
Using a trick I discovered before the repair was scheduled, I took out my iPhone and opened the Camera app. The image that was just faintly visible to the naked eye became dimly readable through the iPhone’s camera. There was no flickering this time; the display was just incredibly dim.
No amount of playing with the brightness keys would change the brightness. I began to wonder what was going on. I switched out her Logitech keyboard for the Apple original, powered the machine down, and held down Cmd-Opt-P-R.
To my considerable surprise, the brightness was reset and I was able to log in. I then subsequently confirmed that the brightness keys do not normally appear to work when one is still at the FileVault password entry screen.
So everything is again functional, but a real mystery remains: what caused the problem in the first place? She is not in the habit of adjusting her brightness, and it seems rather unlikely that she would inadvertently hold down the brightness key while shutting down her computer (which she invariably does using the mouse and the Apple menu – she doesn’t even know there’s any other way.) I just don’t see it. Even if she had managed to turn the brightness down accidentally, she would then not have been able to see the screen well enough to issue the Shut Down command.
Does this indicate that something else is or could be failing in the computer? She was ready to consider replacing it with a new one this morning. I myself am “terrified” at that prospect, as it will be my first experience with Apple Silicon Macs, and I don’t know what challenges lie ahead in switching from Monterey to Sonoma and switching architectures on top of it. Even so, I was hoping to hold out until the rumored M4 iMac arrives, to give her new iMac the most theoretical longevity, but not if her current one truly is on its last leg.
I really don’t want her to have to consider a new iMac unless it truly is time to do so.
Thanks in advance for all help and observations!
