Originally published at: Luna Display Turns a 27-inch iMac into a 5K Display - TidBITS
The Luna Display dongle, when connected to a 27-inch iMac with 5K Retina display using Thunderbolt, turns the iMac into a full-fledged 5K display. However, Adam Engst found that it comes with a fair number of tradeoffs.
Very inyeresting read, @ace. I found your report on experienced performance and conclusions re: potential pitfalls particularly interesting.
I’m always surprised these solutions work as well as they do – even when reviewers justifiably criticize their shortcomings.
Just consider the raw required bandwidth of a 5K display, even at only 30 Hz refresh and using just 8-bit color.
2560*1440*4 pixels * 3 colors/pixel * 8 bits/color * 30 Hz = 10.6 Gbps
(and in reality it’s even 3% more)
And that’s at just 30 Hz! In order to get this image data across a wifi network, even if it’s pretty good wifi, I would expect compression has to get the data rate down by almost 2 orders of magnitude. Even wired Gigabit between only these two clients would still require compression by at least one order of magnitude. Now of course often times (maybe even most times) only few of those almost 15 megapixels need to be updated, but the fact that you can even move a window around and get reasonable refresh and image quality (let alone watch TV) is an indicator that indeed such a dongle solution can compress and push data incredibly well over the network. To me that’s quite an impressive feat in itself. Even if for some workflows/tasks that’s definitely still not good enough.
Oh yeah, what Luna Display is accomplishing is total magic, even with those tradeoffs. I have to imagine that it’s really hard too, since they would have wanted to ship with 5K support if they could have, but it took two years to get it working well enough.
I really, really hope that Astropad can somehow tweak this so I could use a 27"iMac as the PRIMARY display for a Mac Studio
Tempting. Two things keep me from instantly buying one:
I like my secondary monitor to be vertical. I’m not sure I can rig something up to mount my iMac sideways or if Luna Display supports that.
My 2015 Intel iMac is going to eat up a lot more energy than my existing external monitor.
The iMac is fully on I’m assuming.
I think when I’m ready to do this (Mac mini or Studio—close call for my use case), I’ll just sell the 2017 iMac and get a monitor. eBay prices for mine are about $1000, so if I get half of that; it will be worth it for me. And it will continue to work with OS updates.
Amazing what Luna’s done, but I don’t need any more moving parts.
Interesting possibility. Thanks for the review. A video review would enable folks to see what you’re describing and allow them to evaluate its pros/cons for their own use case(s). Does anyone know if such a video review ( perhaps beyond what the Luna folks offer ) exists?
Yes, indeed. I have a iMac (Retina 5K, 27-inch, 2017), and am thinking of getting a Mac Studio. The ‘obvious’ way to go is to buy a Studio Display as well and throw out the iMac. But then I would be spending $1600 to replace the iMac 5k screen with essentially the same screen, plus better speakers and an allegedly better webcam (but there are many reviews saying that the webcam doesn’t work properly at the moment). So keeping the iMac and using it as the ‘Primary’ screen connected to the Mac Studio using Luna and a Thunderbolt cable might make sense. Adam lists some issues with the Luna, but I am wondering whether any of them are relevant to my suggested setup:
- Performance not great - but he was testing with a wifi link, and says that ‘If you were using the 40 Gbps Thunderbolt 3 … the extra speed might eliminate all the interface hiccups’.
- Occupies 2 Thunderbolt ports - not an issue for the iMac (I would only be using it as a screen, so nothing else connected) and the Studio has 4 Thunderbolt ports, so losing one is not a problem.
- Video is jerky - see previous points.
- Apple Watch unlocking doesn’t work - I don’t have an Apple Watch.
- Restarts require App Window rearranging - if the iMac is the primary (and only) display, it is not clear whether or not this will be a problem.
- Kernel panics - this hopefully will not be an issue.
However, the Luna website does not seem to consider this possibility (it does describe using an iPad as a primary display for a Mac Mini, and an iMac as a secondary display, but not an iMac as a primary display).
Do you think this setup would work satisfactorily?
UPDATE:
Luna have said to me:
Thank you for your interest in Luna Display! We expect Luna to work with the new Mac Studio and to allow you to use a 2017 iMac as a display for it, but we cannot say for certain at this time as we haven’t had a Mac Studio in to test with Luna yet.
You should be able to be set up the Mac Studio the same way the Mac mini can be set up in headless mode with Luna. The initial setup process for headless mode would require an external monitor, a mouse and a keyboard connected to the primary Mac since you will need to install the primary Luna app on the Mac Studio.
Yes, the secondary iMac that’s being used as a display is fully on and running the Luna Secondary app. I suppose you could also run other software there in the background, though it might impact performance.
I tried to take some screenshots, but it was hard to compare before and after so I decided not to include them. With a video, I’d worry that compression and not viewing it at full size would present an unrealistic comparison.
I tested with Thunderbolt 2 as well, which was better than Wi-Fi or Ethernet. That’s 20 Gbps, and 40 Gbps Thunderbolt 3 might be better, if it’s a possibility.
I don’t think it’s likely to be satisfying on a production Mac. On every boot, you’d have to have the Luna Display software launch at login and wait for it to connect to the secondary iMac. Anything that had to be done before the Luna Display app ran, like macOS Recovery or even logging in as another user, wouldn’t be visible. Obviously, it’s possible to run a headless Mac and control it via Apple Remote Desktop or the like, but you would probably need a cheap utility monitor for such troubleshooting tasks. In fact, ARD might give you earlier access to the boot screen from another Mac.
8 posts were merged into an existing topic: Using Universal Control in macOS 12.3 Monterey and iPadOS 15.4
Luna Display is also being discussed on this thread.
Catching up here ![]()
- I’ve been using the Luna app for some time to allow brightness control for my third party display. But do I need the dongle to do the external display feature?
- I actually want to get rid of my third party display and use an old iMac as the ONLY display for my Mac mini. Will some Luna product enable this? Claude tells me that I’d have to disable FileVault to get past the initial login prompt in order for Luna to even connect and show me something on the screen. There’s apparently a way to have Luna cache the creds for a planned reboot; but surprise reboots happen often enough and I can’t have no way to see what’s going on…
Luna is actually screen sharing from the MacMini with the iMac. Somehow… Haven’t worked through how it’s working yet… Luna runs on the MacMini and it shares via a Luna Secondary app running on the iMac. I can’t see what you want to happen with Luna.
I recommend keeping a small, compatible flat panel display handy just in case something goes wrong and a physically connected screen is needed.
If your current external display is large enough that it is inconvenient to keep or could fetch a good amount of money, you can get smaller refurbished displays for very little from electronics retailers and next to nothing from various used goods marketplaces.
Thanks. Claude recommended the same :-) It’s unfortunate to have to do that. A screen the size of an iPhone would suffice.
You can even use an iPad as well as the Orion software and a HDMI to USB C converter to make your iPad into a mini monitor. I use this at time to set up headless Mac Minis.
So the iPad will display the initial login screen that appears before the FileVault is unlocked?
Given that it sounds like unless you disable FileVault, the Luna solution will still force you to require a connected primary monitor, how does the Luna solution offer any value over simple Screen Sharing?
My understanding is that the Luna can allow you to have a secondary display, whereas Screen Sharing is just mirroring, right? That sounds useful. But it’s not a way to use an iMac as a the only display, which is extremely useful for all the owners of headless Macs. And given that we’re talking about 27” iMacs, which are plenty big on their own, combined with the the hassle of needing a pre-FileVault login monitor anyway, the use case here of Luna to give you a secondary display doesn’t seem too thrilling.
I think if you’re using a laptop, which always has a screen that can log you in, but is always small, then an iMac is useful as a display. If you really want to have 2 screens and you think that little laptop screen adds much value next to a 27” iMac, then I guess pay the money for Luna. Otherwise, just use Screen Sharing to mirror, wiring them together with Ethernet if you want less latency.
Am I missing anything?
I just asked an AI to identify the smallest display that would work with a FileVault login, and it suggested using an HDMI-equipped 800x480 display of the sort that are often used with Raspberry Pi devices. Such displays seem to be available for US $50 or less. The AI suggested that displays as small as 480×320 could work, though it might be necessary to tweak the login screen.
If true, I’ll count that as an example of an AI getting me to an answer faster than I would have found it on my own.
Edited to add: For example, this one, which has a higher resolution, but is only 7". I also saw an 800x480 display for US $38.
