That’s quite something.
FB et al. learned that you need to appeal to people’s lowest emotions and get them all riled up against one another to get them to keep coming back to your site. That’s how you drive revenue.
Apple would never do that. They would never lock you in, they’ll win you over with their superior products. Your best user experience is all they strive for.
But they also want you to be secure. And you can only be secure if you update all your gadgets. Constantly. Of course only the latest gadgets can be updated and only the latest gadgets on the latest software will continue to talk to each other. And hey, no complaining: Apple’s cut-off is less severe than Android or Windows so it’s obviously all good. So again: no complaining.
Result: at some point your gadgets are either a) unsafe or b) incapable of talking to your other gadgets or c) all of the above. The only way out of that: upgrade everything constantly and that means hardware too obviously, because otherwise no more security. It keeps people coming back for more. And you really have no alternative, since:
remember that the longer you delay upgrading, the harder it’s going to be and the more likely you are to run into problems. Upgrading is a when question, not an if question.
People constantly need to update and buy new gadgets just to keep doing what they wanted to initially do. But with every update they get a little something new and that then adds to the long list of things you need to be able to do but only work with the latest updates, which then require the latest hardware, repeat iteratively from here.
Every crack dealer’s dream come true.
We are becoming slaves to our gadgets. What used to be a tool to get a means done, has now become a means to itself. Buy, update, patch, upgrade, buy again. And iterate. It’s no longer buy and use till it’s actually broken. It’s buy and use until you are told it’s unsafe.
But hey, no complaining. You’re still totally free to do what you want. It’s your responsibility if you choose to run an unsafe system or if you want to keep using a feature you started liking around 2016. That’s all your choice. It’s all on you. Nobody said you needed a computer or a phone. And nobody says you need to be connected to the internet anyway. And Google and MS are worse anyway. /innocent twinkle ;)
