Dear listees:
I have an “old Apple Hard Drive” that is installed in a FW800 external enclosure that also supports a USB-B connection.
I have a USB-B to USB-C 3.1 cable and I am able to get the drive to mount on my MBP M2 Max running system 15.7.7 (24G720).
Given the below information, and what little I know of the upcoming operating systems, will there come a point soon that the operating system will not let me mount these hard drives to my MBP?
The following additional info is provided
Disk Utility says this:
ASMT 2105 Media
USB External Physical Disk • GUID Partition Map
System Info says this:
Old Apple Drive 750 GB:
Free: 536.24 GB (536,239,943,680 bytes)
Capacity: 749.95 GB (749,946,617,856 bytes)
Mount Point: /Volumes/Old Apple Drive 750 GB
File System: APFS
Writable: No
Ignore Ownership: No
BSD Name: disk9s2
Volume UUID: 26506FD7-DFA6-452B-A655-C0464286017A
Physical Drive:
Device Name: 2105
Media Name: AppleAPFSMedia
Protocol: USB
Internal: No
Partition Map Type: Unknown
Untitled - Data:
Mount Point: /Volumes/Untitled - Data
File System: APFS
Writable: Yes
BSD Name: disk9s1
Volume UUID: 9E5DF4E7-D0B1-4F45-94B6-4F62B471DE14
Physical Drive:
Device Name: 2105
Protocol: USB
Internal: No
I looked into the drive and found nothing I wanted to keep.
Using Disk Utility, I erased it and Disk utility reports:
Erasing “ASMT 2105 Media” (disk8) and creating “Old Apple Drive 750 GB”
Unmounting disk
Creating the partition map
Waiting for partitions to activate
Formatting disk8s2 as Mac OS Extended (Journaled) with name Old Apple Drive 750 GB
Initialized /dev/rdisk8s2 as a 698 GB case-insensitive HFS Plus volume with a 57344k journal
Mounting disk
Creating a new empty APFS Container
Unmounting Volumes
Switching disk8s2 to APFS
Creating APFS Container
Created new APFS Container disk9
Preparing to add APFS Volume to APFS Container disk9
Creating APFS Volume
Created new APFS Volume disk9s1
Mounting APFS Volume
Setting volume permissions
Operation successful.
