ChronoSync 12.0.3
Originally published at: ChronoSync 12.0.3 - TidBITS
Econ Technologies has issued ChronoSync 12.0.3, enhancing the cloud-managed folder readiness check to better distinguish between iCloud and File Provider Extension-managed folders. The synchronization and backup tool also updates the way Spotlight indexing is suspended on a volume before unmounting it to prevent a full re-index when the volume is re-mounted, no longer allows storing Sync Task documents in a cloud-managed folder, fixes a bug in the cloud-managed folder readiness check that would fail to suggest switching to an iCloud or File Provider Extension connection type, resolves a crash that occurred when trying to retrieve or set a Finder/Spotlight comment in macOS 27 Golden Gate, and addresses a problem with identifying bootable volumes in Golden Gate. ($49.99 new with a 20% discount for TidBITS members, free update, 102.7 MB, release notes, macOS 10.14+)
