Bookends 15.2.3
Originally published at: Bookends 15.2.3 - TidBITS
Sonny Software has released Bookends 15.2.3, adding Apple Intelligence capabilities to the PDF Autocomplete feature. After initiating metadata extraction from a PDF, Bookends displays the results in a set of reference fields that can be modified or added to before importing. The reference management tool also improves reference metadata extraction from websites using the Bookends Browser, enhances importing of references from existing bibliographies, adds a new Settings option lets you optimize the note stream for display of styled text or for showing right-to-left languages, ensures the font size of notecards copied with a right-click will be the same as that used for the note stream, fixes a bug in the Inspector Cited-In function that limited the number of references returned to 50, and addresses an issue where references having the same title were treated as duplicates when importing EndNote XML files. ($74.99 new with a 25% discount for TidBITS members, free update, 125.9 MB, release notes, macOS 10.13+)
