Anybody have iPhone set up to read to them well?
I was looking to have a web page or part of a web page read to me over my AirPods so I can “read” a lengthy article while strolling across town without taking my eyes off the road and sidewalk.
I failed. Miserably. In 2026.
I had imagined something like going to Reader mode and then either tapping a button or choosing from a menu after long press. Ideally, there would be a quick way to choose either read whole page or otherwise, read starting from here. It would be nice if there were also a quick way to pause/play along the way.
I discovered that through Settings > Accessibility > Read & Speak there are a couple options, but even after playing around with those controls, it left a lot to be desired. Accessibility is usually something Apple’s good at and I cannot imagine there aren’t many others who would want to listen to a long page of text instead of read, at least at times (nothing against reading here!). And yet, nothing really worked well.
  • There’s an option for on-screen controls, but that blob ends up being always on screen, not just when reading out loud
  • There’s no immediate button in Reader mode to evoke/control/end reading out loud
  • I cannot set it up such that controls just become available via long press within in or outside of Reader mode
  • I could never get the swipe two fingers down from the top of the screen method to work
  • Even with speed set to max the reading tempo remained too slow — I can read a lot faster than iPhone could talk
  • English worked well in terms of pronunciation and accent, but German and Swedish were a mess; I have yet to try out French but after what I saw with German, I’m skeptical to say the least
I bet somebody out there must have found a way to make this work in an effective and convenient manner. How am I holding it wrong? And how do I make it do what I want the way I want?
I’m not sure if that’s what the intended use of the accessibility feature is, but you might try an app like Speechify. It seems like it’s more optimized for the scenario you describe
If Reader mode supports the web page in Safari, there should be a “Listen to Page” control.
ListenLater is designed for this, though it’s probably overkill for a one-off:
