Work-Around for Local Calendar Sync-Mass-Duplication
Over 2 years and 3 major OS revs. but I finally worked around some of the local Calendar syncing mass-duplication issue.
The problem seems to be caused by repeating events that are missing the Time Zone field. This can happen if “All Day” is set for the event, or if “Settings / Advanced / Turn on time zone support” is NOT checked. I don’t know if, missing that entry, the parsing code is out of sync and plugging fields into the wrong variables?
It took some work to edit the suspect events in my calendar, but my desktop Calendar seems to be correct now.
This alone has made Calendars much more usable under Sequoia and iOS.
The catch is… initially the problem was when I synced w/ Ventura or later, repeating events (monthly, etc.) would become everyday repeating events. The result was a Calendar so cluttered as to be unusable.
The problem now is that now when I sync to my iOS devices, the events I edited to correct the issue on the desktop are synced, but also some of the old versions of them are synced to the iOS devices. The desktop remains duplicate free. I did not duplicate any of the edited entries, so there shouldn’t have been anything like that remaining. But there is.
First of all, the “Replace Calendars” checkbox claims to completely overwrite the iOS Calendar, but it does not “appear” to. At first, I thought that the older events must be lurking on the iOS device, but after first trying to completely delete the target Calendar, and finally, actually doing a factory reset, the old events still appear after syncing (again, a “Replace Calendars” sync).
The errors are clearly still coming from the desktop. I saved off the current Calendar as an archive, and separate Named Calendar exports. I then deleted all the Calendar data I could find (~/Library/Calendars and ~/Library/Group Containers), opened the (empty) Calendar and imported the separate Calendar exports (1).
The erroneous events still were copied to the iOS device (but still are not showing up anywhere on the desktop.
This is as far as I’ve gotten. Does anyone have any idea where Apple is hiding the rest of this data?
I should be clear that the above has greatly improved the overall issue, just not as good as I would like.
(1) I used the separate Calendar exports rather than the unified archive, because I have found them more reliable in the past. I may try the archive yet.
So Close…
I narrowed down the remaining reproducing events to 3 or 4 events that (through user error?) were actually set to repeat every day, and some corner cases. Cleaned them up.
I had a week or so of happily syncing Calendars and Contacts to my iOS devices with up to date OS’s and with no bizarre repeating events…
Then this morning over my first cup, I got a message on my iPhone from my 11:15 appointment (the top of my phone confirmed it was 11:40). After some apologetic messages, I looked at my Apple Calendars. The Calendar entry on my Mac was set to a 1 hour alert. The iPhone entry was set to “time of event.”
All of the phone entry alerts were set to “time of event.”
The kicker is… even the “time of event” alerts are not “alerting.” All Settings say they are, but they don’t do any sort of alert anywhere.
Yes, this is all repeatable.
I’m going back to a DayTimer. When I find hearing aids better than Apple, I’m trading this iPhone 16 Pro Max in for a retro-dumb-flip-phone.
I have no use for this.
What was especially odd about this is that it was only Calendar alerts that were not working. All other enabled alerts were working fine. WTF?
In frustration, I did a factory reset, and manual restore rather than using the saved archives on my Mac. Calendar alerts are now working.
But the alerts are still resetting to “Time of Event” on sync. And at the last sync, it put up an alert that the sync was going to replace EVERY event on my desktop with the events from my iPhone. It offered an event by event change comparison. The “sync” was simply removing the “time zone” filed from every event, which of course, resulted in the mass duplication of repeating events again… sigh.
I’m now wondering about a wipe and manual restore of my Mac, but it is so much work. Has anyone seen any good advice for a non-Migration Assistant rebuild lately?
Thanks!
I’m very sympathetic to that idea. The feeling that much of my tech has become more of a hindrance than a help seems increasingly persistent.
Nello, thanks for doing the TidBits search I was too frustrated to think of… :-}
Some useful ideas right there in the summaries, starting with simply a clean account.
Just a follow-up:
A clean user account did not solve the issue.
Rather than go to the work of a whole clean install, it occurred to me that adding a second bootable volume on my internal drive might permit a quicker, simpler test. Did so, created a some new calendar events tried to sync to my (wiped) iPad. Same issues.
Occurred to me that AirDrop’ing events might be a modest substitute for syncing, but you can’t AirDrop Calendar events. You can AirDrop contacts.
Feature request submitted.
