Does anyone know of a widget or app that will show me the time of my next alarm going off? I know the clock on the menu bar shows that an alarm has been set, but I have several alarms I flip on and off depending on my need. I would love to have an indicator that says that I have an alarm in the next 12/24 hours that is turned on and is set for X time. Does anyone know of a way to see this data point quickly rather than: open Clock, move to the Alarm pane, scan over the different alarms set for different times on different days and tell me what is happening next?
There is an alarm lock screen widget you can add (which shows up on Notification Center as well.) Pull down Notification Center, long-press and tap “customize”, tap within the widget area under the time and go down to clock, swipe to the right until you get to “next alarm”.
I can’t see a home screen widget that does the same, though.
Home Screen is what I was looking for. But in the Control Centet, I see the alarm, but long pressing only gets me Create New Alarm, and stopwatch stuff. I don’t see the Next Alarm.
Not control center - lock screen / Notification Center. See How to add and edit widgets on your iPhone - Apple Support under “how to add widgets to your lock screen.”
Here is where “next alarm” is.
Thank you! Just what I was looking for.
Upgrading my wife to a new system and trying to explain all the many variables in the OS, and there are still things I have not stumbled upon.
