Am I being thick? I don’t use scripts very often, but there was one I used to find really helpful. Using it you could easily remove or add characters to filenames. When I looked under the script icon recently to perform this action I discovered that there are very few scripts there any more (I upgraded to Mojave a couple of months ago). There used to be dozens, in various different categories.
Where have they all gone? I don’t remember ever installing them. I thought they came with the OS. Has Mojave abandoned them? There are a few still, in folders called ColorSync, Folder Actions, Font Book, Printing Scripts, Script Editor Scripts, UI Element Scripts, and VoiceOver. But none for doing stuff in Finder, like changing file names.
Is there any way of reinstalling them? The usual Google search isn’t proving too helpful.
I’ve found over the years that many of those older scripts no longer work with the then current OS and wondered why Apple kept them around. Apparently somebody decided it was time to clean house.
Yes, I had in fact discovered the rename task (by right-clicking on the file selection) and it could be of some use. Unfortunately it will strip names of a character string wherever it occurs, not just at the start, so wasn’t quite what I was looking for.
