Whence Print Center?
I might simply be going insane or have some sort of wrong setting on my phone.
Print Center is gone. I print something from my iPhone, and it no longer shows Print Center as an app in my running list of apps. Swiping up and it’s no longer there just to the right of the last app.
Did Apple remove (or more likely moved) Print Center from iOS?
It’s still there.
As i recall, it only shows when a print job is actively printing.
Yes. It use to show up when there was a print job.
It’s not showing up any more when there’s an active print job since iOS 18 came out. At least I can’t find it. I checked my Settings and I checked the App Store.
Printer Center is a Control Center widget. If you bring up the control center, tap the ‘+’ in the upper left corner to bring up the edit display. At the bottom, you’ll see a button to add controls. Tap that and search for ‘print’. Add the widget that appears to the control center and exit. You can now access the Print Center by tapping that widget. Note that printing shows up as a Live Activity when you print a file.
Yeah, I found it. Thanks.
Why don’t they just make it a full blown app? They did the same with the Apple TV remote too. You can only bring it up with Control Center.
