This thread has raised a lot of issues for me.
surge suppressors
Way back in May 1988 I did a deep dive into surge suppressor technology and then wrote a comparison review for MacWorld titled They Can’t Hurt where I tried to make the case that you need to spend real money if you actually feel you need an effective surge suppressor. I suspect that’s still the case almost 40 years later. Still, the piece ended up being quite controversial.
I have lived in various parts of the US – rural, suburban, urban; publicly owned vs. “investor owned” utilities; house wiring from knob-and-tube to state-of-the-art. I have always owned a lot of traditionally sensitive electronics – audio gear, musical instruments, amateur radio equipment, minicomputers, briefly an IBM 360 (408 volt 3-phase power), many servers, desktops, laptops, and the occasional television set. I’ve been through many power outages and a few lightning strikes. I have never, to the best of my recollection, lost a piece of equipment due to power issues. I haven’t used high-end surge suppressors but probably most always had my equipment plugged into a power strip which probably had a $2 MOV in it. I’m not at all saying that there isn’t a legitimate need for surge suppressors, and it’s almost certainly the case that I’ve been lucky (one of the lightning strikes split a utility pole about two meters from my bathroom window, and I was using an electric razor at the time). That is my experience, though, and I think it’s a useful data point.
I should probably also point out that I always had lightning arrestors on my radio antennas and was fairly fanatical about grounding things.
UPS
I have run a server farm out of my home since the late 1990’s. At one point I had almost 100 servers running (I remember thinking about buying a handful of Raspberry PI’s to round out the number). I often had much of the gear running on “uninterruptible” power supplies. I always kept a couple of servers connected directly (well, probably through an MOV-equipped power strip) to mains as canaries that could alert me when the UPS systems were in play. At the end of the day…
I have had more downtime from poorly designed and/or faulty UPS systems than I would ever have had from power failures or other grid faults. By a factor of at least ten.
I could (and here I did) wax eloquent about the many problems I’ve had with UPS systems. I am not a fan.
power stations
I got a really good deal on an off-brand 2,500 watt 2 kilowatt-hour portable power station. About $500 IIRC. I bought it completely on spec, then a year or two later moved to an off-grid home in Hawaii. For a few months, we were running exclusively on generator power and the power station was an absolute godsend. It is so useful and great that I tried to buy another one, but finding one on the island is a challenge in and of itself and when they do show up they’re north of $2,200.
backup generators
I think I now have enough solar power that I’m unlikely to ever need my backup generator, but over the years I have learned that it is essential to test them frequently, and under real-world load conditions. I’ve tested mine several times since I brought the big solar plant online, and it all worked fine – until we had a dark, stormy day and had been driving the electric car a lot. With a real load, the backup failed. Just like your backup files, test your backup power under real-world conditions.
Remember, also, that when the grid fails it often doesn’t fail cleanly. Flipping off your grid-connected breaker in no way simulates the fits and starts of a grid going down and reconnecting.
Tesla Powerwall
I bought Tesla solar and a Powerwall many years ago. I would never buy anything from Tesla ever again, regardless of how I might feel about the antics of the CEO. The company acted unscrupulously. That could just have been a bad apple (apparently, though, there are many), but they also require that you maintain an internet connection for your Powerwall at all times, and they control how and when you can use it. For example, they wouldn’t let me load-shift (charge from the grid during off-peak hours so that I could run from battery during peak hours). They wouldn’t explain why, but later (after I’d sold that house) entered into a deal with the “investor-owned” utility where they would allow load-shifting. I’m guessing that they directly or indirectly profited from that deal. Bottom line: you can pay for a Powerwall, but you don’t own it or control it, Tesla does.
The Powerwall otherwise worked well, but when grid failures occurred, the transition from grid to Powerwall was not smooth enough to keep servers from crashing. Again, if I just switched the breaker, it would work fine, but the grid dying was dirty enough to reset things even with the Powerwall in play.
