OP here. I purchased two 60W equivalent (8.8W actual) Philips Smart LED “Connected by Wiz” Full Color (RGB) bulbs from Big Box Orange to test them out. $12.97 each with discounts of 5,10,15% for the purchase of 2,4,6 bulbs.
They were the same price on Amazon individually; I don’t recall if discounts were available for purchase of multiple bulbs.
With two days of testing I am quite satisfied with their operation and have ordered two four-packs of the 100W equivalent bulbs.
The Wiz app is free for download on iOS or Android. I have an iPhone, so any comments from me should reflect that.
You can pair the app (and phone) to each bulb individually via wi-fi. No hub or third-party needed. Bulbs can be grouped, arranged by room, scenes set up for quick access to either their default programs or your set ups. You can set Time-On and Time-Off individually or by group.
In addition to full-on white, many colors can be set. I have settled on one of the default selections (true color) which is white with a yellow cast. There is a color wheel from which you can set your own color, but I have not tried that yet.
The “Integrations” feature allows you to connect to Matter, Alexa, Google, SmartThings, IFTTT and at least eight other controllers that I have never heard of.
You can allow multiple people to have some, mid or all control over the bulbs operation. No need to create and account with Wiz or Philips.
Most importantly, as all the brains of the operation exist on your phone, if the house power goes out, bulb programming is NOT affected. I pulled the plug from the wall for an hour and two hours after replacing the plug, the time came for the lights to come on and they did.
At this point I have not tested what would happen if my phone was not in the house at the time an ON or OFF was supposed to happen. There are several mentions of remote operation so I supposed everything might work, but don’t know if I need a Wiz account or what. But again, I’ve only had the bulbs for two days and it was a learning curve to get to this point.
So far, I’m quite satisfied with their operation. More opinions to come in the days ahead.
