I just noticed that I have apparently deleted a key entry in Contacts (macOS 10.14.4).
Is there a way I can open and view my contacts in a backup (clone or Time Machine) without overwriting my entire file?
Another solution?
Thank you,
David
Another solution?
Thank you,
David
Thanks for the tip.
I tried it but it only goes back to March 20, 2019, and apparently I deleted the contact earlier than that.
I also tried rebooting from my oldest clone (January 12, 2019), but that isn’t early enough either.
If I restore from Time Machine and copy out the contact information I need, I guess I could restore again from the most recent Time Machine to preserve the changes that have been made in the meantime?
David
Update:
When I try restoring Contacts from Time Machine, it says, “No card selected.”
Does this mean you can’t restore all your Contacts from TM?
David
