About a month ago, I updated my iPad Pro M4 and iPhone 13 Pro from iOS/iPadOS 17 to 18.1.1. Last night on my iPad I was investigating the new feature that adds reminders with a date and time to the Calendar app. Great idea, but in typical Apple fashion the implementation leaves something to be desired. Namely, that it works.
There in my iPad’s calendar were reminders that had been completed ages ago. I puzzled over this for a while, and then decided that I could go into the Reminders app and delete completed reminders, since I never review them. I had over 5,000 completed reminders, which I cleared, to use the app’s terminology. This worked around the problem and my calendar now showed only active reminders, though obviously having to take the step of clearing completed reminders each time I actually complete one - so that it doesn’t continue to appear on my calendar - is not something I look forward to.
I then noticed, still on my iPad, that the Reminders app was prompting me to do an update. I had ignored this previously. It says “To use all the latest features, tap update.” So I did. The gear spun for at least five minutes, then stopped, with no apparent change. Then the update request reappeared. A few minutes later, I tried again. This time, with the gear spinning, many completed reminders reappeared in my Today view and, correspondingly, in other views. I went to look at completed reminders, which had been at zero after clearing them earlier, and there were over 4,000.
The gear kept spinning with no other noticeable change. After a half hour, the gear was still spinning. I force quit the Reminders app and restarted it. Still spinning. Still showing completed reminders. I closed the cover of my iPad and went to bed. This morning, the gear had stopped, the regurgitated reminders were gone, and the request to update the app reappeared.
However, the completed apps are still in the Completed list and have now reappeared in the Calendar app.
So, I have some questions. Why does the Reminders app want me to do an update outside of an OS update? What features is it supposed to add? Why is it refusing to update? Why is the update at least temporarily restoring completed reminders and why did my cleared reminders return to the Completed list? Why are completed reminders showing up in the Calendar app?
(A quick search of the Apple Support Community shows someone having this problem of regurgitated reminders in iOS 17 and another person on, wait for it, MacOS 10.4! Obviously a long-standing bug that Apple doesn’t deign to fix. But we have Genmoji!)
