I’m experiencing abysmal battery life on my Series 4 under watchOS 7, and I’m wondering if any of you are seeing the same thing? I put my watch on at 8 AM, and here just before 2 PM I’m at 43%. It’s actually dropped three percent just in the past few minutes.
Someone suggested that the handwashing timer is draining the battery, but I checked and mine was turned off by default. You can check that on the watch under Settings > Handwashing.
My Apple Watch 4 is doing very well under watchOS 7. So lets look as some possibilities, you can ask me about any settings.
I had hand washing on most of Saturday and turned it off Saturday afternoon since I wouldn’t be able to charge it until Sunday afternoon. I got around 30 hours from that charge.
Is this a cellular model? Mine isn’t. I suspect cellular is more apt to drain the batter. But if not that, something else.
Any other apps that run in the background. I can compare to mine if you wish.
My S5 has been about the same. (It’s hard to say, it’s only been a few days.)
In the past when I’ve had sudden watch battery drain (which has happened a few times in almost four years) a restart of the watch has sometimes fixed it, a restart of the watch and phone has always solved it if just restarting the watch hasn’t. It’s worth a try to avoid the time of an unpair/pair cycle.
Restart did not fix it for me on my S4, but unpair/repair seems to have done the trick. It’s amazing how easy and painless the process of repairing and reinstalling everything from a backup is. Hardest thing was reinstalling my debit card on Apple Pay.
James
Nothing has changed as far as battery life on my WiFi only series 4 since installing iWatch 7.0… I’ll turn handwashing on and see if that changes anything tomorrow, but judging from other comments, I don’t expect it to.
I unpaired and repaired and that seems to have improved it. It’s at 77% right now after about 7 hours of wear. I accidentally set it up as a new watch, if that makes any difference.
