Originally published at: https://tidbits.com/watchlist/pages-8-2-numbers-6-2-and-keynote-9-2-for-mac/
Maintenance updates bring support for adding HEVC-formatted movies to documents. (Free, various sizes)
the article quotes “macOS 10.13+”. I believe this is incorrect: High Sierra (10.13) did not want to update to the x.2 Numbers/Pages/Keynote, and when I looked it up on the Apple site, it stated x.2 required 10.14+ (Mojave), which did accept the updated version.
Thanks, I’ll fix that. It can be tricky to know when system requirements change if the release notes don’t call it out specifically.
Hi Adam,
thanks for fixing the note.
Yes, you’re correct. It took a little investigation effort for me to confirm the macOS versions which would accept the Numbers/Pages/Keynote updates.
—Phil
