I’m hoping people here can help me fix this–AppleCare Level 2 wasn’t much help.
Hardware:
27-in. 2020 Intel iMac
Ventura 13.7.8 (yes, I have a reason for sticking with Ventura for now)
Yes, it’s plugged into a UPC
House power went out; I shut down Mac normally while it was running on UPC power, but did not manually shut down Mail first (in case that matters). Mail had several emails open on desktop, and (somewhere) it’s set to restore whatever state it’s in when I close it.
Power came back on; I rebooted, then opened Mail.
Mail opened normally for about 20 seconds, then crashed while restoring previously open emails, etc.
I’ve run through all the obvious things to try, up to and including re-installing Ventura, but Mail always crashes at one of the same two points. I know just enough to spot that in the crash reports, but not enough to know what it actually does or how to fix it.
Thread that crashes involves MFEWSPeristenceTaskHandler, OR–
When I’ve just done a cold reboot, it’s always IMAPNetworkTaskHandler.
Here are the summaries for both those situations, followed by links to the full reports.
Translated Report (Full Report Below)
Process: Mail [4411]
Path: /System/Applications/Mail.app/Contents/MacOS/Mail
Identifier: com.apple.mail
Version: 16.0 (3731.700.6.1.21)
Build Info: Mail_App-3731700006001021~2
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 502
Date/Time: 2026-03-19 13:15:37.1282 -0700
OS Version: macOS 13.7.8 (22H730)
Report Version: 12
Bridge OS Version: 9.6 (22P6083)
Anonymous UUID: 08AE973F-3199-47AC-836D-A1B29DA8DB23
Time Awake Since Boot: 10000 seconds
System Integrity Protection: disabled
Crashed Thread: 44 Dispatch queue: MFEWSPersistenceTaskHandler queue (QOS: BACKGROUND)
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process: Mail [4411]
Application Specific Information:
abort() called
Process: Mail [4271]
User ID: 502
Date/Time: 2026-03-19 13:10:37.8559 -0700
Report Version: 12
Time Awake Since Boot: 9800 seconds
Crashed Thread: 14 Dispatch queue: IMAPNetworkTaskHandler queue (QOS: BACKGROUND)
Terminating Process: Mail [4271]
abort() called
Dropbox Link to Full Report–MFEWSPersistenceTaskHandler.txt
Dropbox Link to Full Report–IMAPNetworkTaskHandler.txt
Can anyone figure out what’s actually failing here? And is there a straightforward (e.g., command-line) solution? I’m comfortable entering commands via Terminal, but would need to know the exact command(s) to enter. And for various reasons, relying on email-via-browser (or my phone) is a stopgap at best.
Many thanks for your thoughts, suggestions, etc!
Levanah
