I’m intrigued by the Camera button, which is really a one-dimensional trackpad. Seems like a great idea. In fact, I’m a little surprised they didn’t replace the separate volume buttons with something like this. Maybe next year.
I’m still using an 11, which is still fine, really. I have been kind of holding out for the 16. This is hardly an earthshaking upgrade over the 15, but I’m ready to take the plunge.
If you are photo centric - the regular iPhone 16 models do not have Apple ProRaw photo format or Apple ProRes video format. The regular models have a USB-C port that supports USB 2.0 (480 Mbps) speeds where the Pro models have a USB port that is USB 3 speed (10 Gbps). In the box of all models is an “USB Charge Cable”. It is doubtful that the cable meets the criteria for USB 3 speed transfer - I have read that it supports USB 2.0 speeds. In my experience with my iPhone 14 pro, I find the ProRaw captures skies with clouds much better. Some photos get improved shadow detail. These improvements are not as dramatic with those I get from large sensor digital cameras. Because I use the ProRaw format, I often transfer via cable and the process is quite slow via the USB 2 lightning cable.
I can confirm that the “charge cable” included with the 15 series iPhones is not compatible with any data transfer >480 Mbps. So certainly no USB3 or TB. I’m almost certain there will be no change with what is included with the 16 series. It is a very nice lightweight and flexible braided cable, just a shame it’s not really good for anything except charging.
For those of us with an older model like the iPhone 11 a big reason to upgrade is newer radios (5G + satellite). My iPhone 11 is still a nice enough hand held computer but the radio has fallen behind the available network. Since I anticipate keeping a new iPhone for 4+ years, the amortized cost is a smaller consideration (your budget may vary). Some of the Pro features could come in handy.
Incremental upgrade over a 15 Pro, but of course it would be. In truth I don’t actually need the photography features of a pro, it’s just that Apple never brought lidar and USB 3.2 gen 2 transfer speeds to the standard iPhone. The batteries are better in the pros, too.
I was very briefly tempted by Wi-Fi 7, which is uniquely available across all the 16 models, and which would definitely present a meaningful upgrade on my network. But 6E already gives me the speed I need in my small and well-covered flat, so that can wait for something more material. The standard phones are catching up to the pros, in truth, and I have great hope that this trend will continue. My battery health is 92%, so by next year I’ll probably be keen to consider an upgrade. I prefer strongly to upgrade only when there’s a clear need; for the 15 releases, USB-C was definitely the deciding factor.
I’ve switched from an iPhone X to a 15 Pro Max last year. Originally I contemplated just having a new battery installed in my iPhone X and use it until important apps wouldn’t update anymore but in the end I caved to the vastly better camera on the 15 Pro.
I don’t see any use in Apple Intelligence and am not a professional videographer so unless Apple, at some point in the next few years, comes out with something that is ‘insanely’ better then my phone is now, I might keep on using it until it stops working (and maybe try and best my six year streak with the iPhone X )
In photographers there’s a well known phenomenon called GAS (gear acquisition syndrome) and manufacturers in every sphere are trying to expand it to every product imaginable.
Before I bought my iPhone 14 Pro I had an SE and I’m definitely going to try to stretch this phone out for at least another release cycle.
I’ll never buy a new phone every year but it will save a fair bit if I can stop two year updates and do three or four year update. I doubt I’ll be missing anything except GAS.
