Perhaps somebody at Apple has been reading this thread. ![]()
I use Camo with Zoom calls and I am usually the clearest looking person on the call these days. And I’m not even using the paid features which allows for 1080p and color adjustments. I do feel like buying some lighting since all of the lights in my room light up the walls, which are salmonberry, which in turn makes me look orange. On a sunny day the color is much better with light from the outside.
It’s great that Keynote Presentation in a Window now also opens a separate Presenter window. Another way to work with a presenter screen is also open Keynote on an iPad or iPhone and use the Keynote Remote option to display the Presenter window on the device. The only problems here is that while the computer version of the window shows the currents slide, next slide, and presenter notes, the Keynote Remote version only can show 2 of 3 (your choice).
I use my iPad as a remote so I can use the “laser pointer” feature to draw attention to what I’m talking about, and occasionally, I will write something on the slide as I talk. When you go into that mode, however, you lose the presenter display on the iPad, which is inconvenient if you want to see your notes.
This is tremendously good news! It solves a lingering problem (and puts Keynote a leg up on PowerPoint for Mac).
The one fly in the upgrade ointment: Keynote 11.0 is only available for macOS 10.15 and 11.x.
Nobody at Microsoft has! (Yet?)
Actually, you now have the best of both worlds. On your Mac, run the slide show in a window which will also open the Presenter window (with your notes). Use the Keynote Remote option on your phone with the same slide show in markup mode. Share the Slide Show window and adjust the Presenter Window to a reasonable size so that you can use your notes. Now you can see your notes but control the show (including pointing and marking up) from your phone.
That is a superb tip, Alan!
