Originally published at: Hazel 6.0.4 - TidBITS
Noodlesoft has issued Hazel 6.0.4 with added support for the Brave and Vivaldi browsers. The automation and cleanup utility now enables you to export custom list attributes via JavaScript, correctly displays the paused status of folders in the menubar item menu, updates preview updates correctly when rule options are changed, fixes a bug where using the key equivalent to focus on the search field failed, resolves an issue where Rule Status highlighted the wrong fields, fixes text recognition for files with rotated pages, and makes functions found in the Finder extension contextual menu now also available in the menubar item menu. ($42 new, free updated, 27.5 MB, release notes, macOS 10.14+)
