Originally published at: GrandPerspective 2.5.3 - TidBITS
Brings support for M1-based Macs and macOS 11 Big Sur to the graphical disk usage utility. (Free, 3.1 MB, macOS 10.9+)
That first link is broken. You need to remove the s on https.
I’m not seeing a broken link and the SourceForge link in the piece is HTTP, not HTTPS. Could you be using an extension like HTTPS Everywhere?
Hmm. I’ve never heard of that so I don’t think so.
I tried multiple browsers, many times, no luck. Finally I copied the link and started altering it to try to get it to work. When I removed the “s”, it worked.
Maybe I will do more experimenting. If I’m the only one with the issue, move along! ![]()
