I have to update someone’s website and the host only allows access via ftp (or via very terrible web). The finder doesn’t mount ftp sites with rite access anymore.
I am managing the ftp via the command line, but I would prefer to mount the ftp so that it shows in the finder. Since this is a short term issue, I also don’t want to buy anything.
You could try Cyberduck which I used years ago for a while. It doesn’t mount the server in the Finder, but it was a competent (and free) ftp/sftp client when I used it. Haven’t used it in a few years though, resorting to Fetch when I (rarely) need ftp.
I assume you realize how insecure FTP is, so consider your password compromised when finished with your project. That’s the reason Apple eliminated Finder access to it. Try to convince that someone to adopt a secured FTP protocol ASAP.
Not free but ExpanDrive mounts ftp, sftp and cloud drives in the finder. Does a sync without actually downloading files so you can have a listing of files and folders and navigate/organise etc. Recommended.
There’s also Forklift which offers FTP access but it’s within its own window as a Finder replacement.
I haven’t willingly used ftp in at least 15 years, but astonishingly there are still web hosts out there requiring it to access the site’s files. I ended up simply grabbing the entire site with ncftp and editing it locally and then putting everything back.
Thanks for the suggestions. though, hopefully I’ll never have to do this again.
