This is the second time this has happened with my MBP M1 Pro in Monterey. All the items I added to the Finder left-hand sidebar vanished overnight. And all my Finder tabs got reset to some default location. So I had to hunt them down and pin them to the sidebar again.
Anybody else see this happen? Apple support is completely unhelpful about this.
The only time I’ve had this happen is when the Sidebar items are for folders that live on a shared drive. If the drive doesn’t successfully mount at startup, which happens occasionally, all those items vanish and I have to add them again later.
still happens on my Snow Leopard machine, and my High Sierra Mac, and my Monterey Macs. A long-standing bug, in other words.
Also, I agree it is triggered by a remote disk not being available when one clicks on the Sidebar folder. On some occasions, the remote disk will be mounted by clicking on the Sidebar, other times, instead all the Sidebar items are removed (even local ones, with the exception of the folders built into the OS – Documents, etc.)
If a remote disk is the same thing as an external one, I don’t think this could be the cause for me either.
Also, I had been using Favorites in the sidebar for many years – ever since the first OS X – but never had the problem until a couple of months ago, and then twice within a few weeks and not since then, even though I have not changed my workflow that I know of.
Have seen the same problem myself. Even without links to external or networked drives.
Here’s a workaround kludge. Now I know this will sound very much like duct tape, superglue, and bale wire, but hear me out. I actually take a screen shot of a few app’s main windows just for this purpose. Every once in a while I’ll have to resort to them to see exactly how I had things set up before macOS decided to nuke my setup.
Now obviously, a much cleaner solution would be to rely on backed up plists and such. Alas, with 10.9 cfprefsd came along (which otherwise offers a lot of good stuff) and things get cached, overwritten, or remotely stored in obscure fashion (Safari bookmarks in iCloud) so that I often found myself unable to recreate what I had had previously just by restoring the pref file. So while these screenshots are a silly workaround, they have for me become the least time consuming method to fix whatever gets lost when macOS next time decides to rid my Finder sidebar, or remove my XQuartz key caps, or nuke my Mail.app toolbar icons, or create lasting discrepancies between my Safari Bookmarks on iOS and macOS or some other dumb bug that should never had made it past beta testing in the first place.
@Simon
The screenshot approach is the only viable way to recover from things like ⌘+ or ⌘- or rotating one of two screens in the same space. Most often for me, it is inadvertent size changes which cause icons to scatter apparently randomly.
(Apple Configurator 2 allows capturing iDevice home screen layouts for posterity, but it is atrociously clumsy at editing.)
Hasn’t happened in Sonoma, but what I did the last time it happened in Monterey (I haven’t upgraded my primary machine to Sonoma yet) was to take a screen capture that I can refer to re-create windows. I suppose I could make aliases to all my standard windows, since you can’t save a ‘tab set’ of Finder windows and use that to re-open them. I typically have a fairly static set of tabs over time in the Finder.
I don’t think it’s happened to me since Sonoma (yet).
In refreshing my memory before I replied, I read your comment above from October. I too have lamented “tab sets” in the Finder, and finally wrote a little AppleScript that opens a Finder window with a pre-set selection of tabs. I can post it here (I think) if you or anyone else is interested.
100% interested! Hmm. Was thinking that one could write a “polling” routine that would examine Finder tabs (and maybe sidebar items?) and store those nightly? Not asking you to do the work! I am irritated by this bug because it wastes my time—but about 10 minutes across a year. I’ve probably spent more time writing about it!
