Error code -1008F after erasing Intel-based Mac
I have a friend’s daughter’s 2018 MacBook Air (Intel, obviously), that I erased in an attempt to set it up for her ‘as new’. I rebooted after erasing it, assuming I could boot from my bootable flash drive with Sonoma on it. Well, now all it offers, no matter what I try, is Internet Recovery, and every time I get to the end of that slow process, I get the triangle with an exclamation point, “support.apple.com/mac/startup” and the error code -1008F.
I’ve tried all manner of keyboard shortcuts at bootup: just the Option key, ⌘-R, ⌘-⌥-Shift-R, and none at all. I’ve tried two different wifi networks (I have several in my house) and ethernet.
Anyone have any suggestions, or have I simply bricked this thing?
P.S. I’m thinking I probably should’ve changed the security settings before I wiped it; is that right? Is it too late now? Sigh…
Apple Support article regarding -1008F: If your Mac starts up to error -1008F - Apple Support
This says you may be ok if you use Option-Command-R (without the Shift), but it may well be that you are being blocked the Activation Lock. In which case the Support article is: Activation Lock for Mac – Apple Support (AU)
Before going further ask the owner if they enabled Find My. If so, get them to remove the Mac from their Apple ID. See the second part of How to remove Activation Lock – Apple Support (AU)
FindMy and Activation Lock are an anti-theft mechanism.
All the above assumes I have made a decent guess at the cause of your troubles. I may not have!
Could you or Adam please change the title so we can easily find it in future - the tips and links from Gilby are very useful.
Maybe “Before you erase an Intel Mac check this experience”
Sorry, really good point. Looks like Adam already changed it. Thanks @ace!
FYI, I got the daughter to remove the laptop from her account, but I’m still getting the same error. Interestingly, however, first, in trying to turn off Find My, and then when I had her remove the machine via System Settings->Apple ID on her new machine, she encountered “unexpected errors”. Not sure if that’s playing a role as well.
I’ve sure learned a lesson here, regarding newer T2-based models, as well as all the M-series. In my experience, Apple has done a good job creating a process that avoids issues like this on M-series models at least…
