Undestood, but nevertheless, periodic black-outs like this indicate a loss of sync. Usually, this is the cables, although it is certainly possible that there’s a problem with the computer or the display.
Unfortunately, proper testing of a cable (to generate an eye pattern diagram for analysis) requires specialized equipment that is too expensive to buy if you’re not in the business of manufacturing or certifying equipment.
I have seen plenty of occasions where getting a static shock from a metal surface (usually during the winter) near an HDMI-connected device caused the picture to momentarily black-out.
I also know that USB-3 cables have been known to interfere with Bluetooth. I haven’t heard of it interfering with HDMI, but cable-to-cable interference is not without precedent.
So, if you’ve got a rats-nest of cables behind your computer, maybe see if organizing/moving them helps. If EMI proves to be an issue, consider cables with heavier shielding.
I have a studio filled with Mac Studios and Dell monitors on campus. This is a constant issue. I turn on and off the Dell monitor if one of them fails to come on and it works.
I want to echo @tommy’s comment. Very similar situation here. Seen it plenty of times between Macs and Dell monitors here at the lab (not trying to say it’s an issue with Dell monitors — we just have a lot of them because they’re good screens). Even if we use quality DP or HDMI cables instead of USB->whatever cables or make sure there are no TB hubs in between, it always ended up happening from time to time. Usually turning the monitor on/off (like @tommy suggests) or opening/closing the MB lid revived external output.
I will say though that, for me, since I upgraded my main work MBP to an M4 Pro, I have yet to see the problem appear, this is with my trusty old Dell U2720Q.
