I hope that someone might have experience in moving MS Office 2011 (32-bit) for Mac into OS X 12 in Parallels so it continues to run under OS X 15 and later (64-bit only) and would be willing to share their knowledge.
My work relies heavily on MS Word 2011. Over the years, I have extensively adapted it to my workflows and have developed about 30 macros and several toolbars that make my work doable. I have previously tried upgrading to Word 2016 and Word 2019 and have been dismayed to find that many of the functions on which my tools and macros are based have been removed, to the extent that I can’t do what I need. (My work is highly specialised, and my reputation with my clients relies in part on my fast turnaround times and in part on my skills with MS Word.)
So upgrading MS Office is not an option.
I’ve investigated moving to LibreOffice, but rewriting the macros is beyond me, and paying a consultant to rewrite them is prohibitively expensive.
So LibreOffice is not an option.
I recently bought Parallels with the intention that it would allow me to continue to run MS Office 2011 in a Sierra environment when eventually I need to upgrade my Mac. (I use a Mac Pro 5,1 that is maxed out on processor and GPU and has gobs of RAM, but I have my sights set on a Mac Pro 7,1. But even before that, it’s likely I’ll have to upgrade to a later OS to maintain security.)
Parallels would allow me to run Office for Windows, but I will not install or use Windows. That is not negotiable.
MS Office 2011 is a 32-bit application, which Catalina and later won’t run.
The obvious solution is to continue to run Office 2011 under Sierra in Parallels. I have installed Sierra in Parallels and copied MS Office into it. But this is where I run into Microsoft’s inflexibility.
In the past, when I’ve upgraded computers or had to replace the HDD or SSD, almost all of my software continued to run seamlessly on the cloned volume. The big standout exception is MS Office, which behaves as though it’s a new installation and requires reregistering. In the past, reregistering has been doable, if annoying. But since Microsoft has abandoned Office 2011, the option of reregistering has been removed. The last two times I’ve replaced the HDD/SSD, I’ve had to resort to calling Microsoft and ended up talking with support bods who follow scripts that try to encourage the caller to upgrade. On each occasion, with persistence, I’ve managed to get my query escalated to someone who knows how to reauthorise an existing installation, which has involved multiple transfers, multiple holds, repeated explanations of what I’m trying to do and recitation of strings of letters and numbers. Both times the exercise has left me close to tears and emotionally exhausted, just for the right to continue to use software (the licence to which) I legally own.
I don’t want to do this again.
So to my question: Is there a way I can transfer the current, functional, legal installation of MS Office 2011 from my current Sierra environment into Parallels that will avoid MS Office demanding that I reauthorise it while preventing me from doing so? (The computer and SSD are the same, although I suspect that MS Office will regard the Parallels environment as a new computer.)
If there’s no workaround, then I plan to engage an IT consultant to do it for me.
