Originally published at: https://tidbits.com/2018/04/20/cloudflare-and-quad9-aim-to-improve-dns/
The domain name system is largely insecure, leaking information and subject to compromise. New services from Cloudflare and Quad9 could provide greater security and integrity than Google Public DNS, currently the best known public DNS service.
If I change DNS on my iMac or iPhone, do I need to change it on my wi-fi router as well? In other words, does the DNS setting on my iMac or iPhone override the setting on my router? If not, Iâm thinking I can just change the router DNS and not worry about changing it on individual devices.
Yes, router is easiest. Some proviso:
You canât change it easily on an iOS device, as you have to change it network by network. So you could change it for your home and routine networks, but Adam Engst has seen these changes not stick, and revert to automatic DNS server assignment as provided by the network gateway.
If you set it on a router, you donât need to do anything with the devices that connect to the network. However, you might choose to set DNS servers manually on a Mac laptop, as you might want to use those DNS settings when youâre off a network you have control over.
The DNS setting on my iMac or iPhone override the setting on your router. Changing it on your router, can make it less time consuming for those with multiple devices.
Some missing information that may solve some issues:
The IPv6 addresses should also be entered for Cloudflare in case your ISP uses them;
2606:4700:4700::1111
2606:4700:4700::1001
Some browser extensions that are linked to actual apps may fail to function properly after using the Cloudflare DNS. An example of this is the password manager, âSafeInCloudâ. This is a browser issue, not the App as in Chrome the issue does not occur.
The simple fix is to add âlocalhostâ into the âSearch Domainsâ the same way you entered IP addresses into the âDNS Serverâ box after noting the current search domain and adding back in after you entered âlocalhostâ into the search domain.
I personally would appreciate it if you did not add the âlocalhostâ fix into the Cloudflare knowledge base but instead refer them back to this Tidbits article or Apple support or Sonic ISP for assistance who have received this information. This are organizations that offer real support. Cloudflareâs only support is to refer users of the 1.1.1.1 to a community knowledge base which is essentially no company support, depending on users to fix issue by themselves. As such I prefer to direct users for support to organizations that offer real support and value their users time, effort, and contributions by offering actual support from the organization employees when it is needed and the information does not exist in self-service support tools.
Cloudflare looks interesting, but how does it compare with DNSCrypt?
I suspect that using both would be counterproductive, so is Cloudflare a better option than DNSCrypt, or are they just alternatives offering the same solution?
I think that DNSCrypt is a protocol that enables the provision of secure DNS. It is an alternative to DNS over HTTPS (DoH), which is what I believe Cloudflare uses. I donât know how the two compare in practice, but DoH is a standard, I believe.
Do you have an opinion on DNSCloak? It seems like the easiest way to change the DNS on iOS, and the only way to use an alternate DNS for mobile data.
Some routers can over-ride the DNS servers that are set on your device. For more see
https://www.michaelhorowitz.com/DNS.and.Routers.March.2018.php
So, even a Mac with hard coded DNS for Cloudflare, may well use other DNS servers when at a public WiFi network. The good news is that you can test for this. A list of websites that tell you the DNS servers actually being used are here
https://www.routersecurity.org/testrouter.php#DNSserverTests
If you override DNS settings on a Mac, my recollection is that it doesnât apply any fo the DHCP-provided values. IPv6 responses are returned from IPv4 DNS servers, so that shouldnât cause any issues to just use IPv4 addresses.
DNSCrypt was a proposal that never got folded into standards.
Interesting option, because from what I can see is it uses a profile, which allows it to do this override. I havenât tested it. Iâd rather see Cloudflare and Quad9 develop an iOS profile that you could just install, or a third-party developed a 99¢ or $1.99 app, the sole function of which was to let you switch between DNS providers.
Having tested DNSCloak, this seems to be what it is (except itâs free). It lets you choose (a) DNS provider(s) and then you can connect and override the DNS your phone was using. As you say, it does this via a (VPN) profile. I donât know enough about networks to verify itâs behaving properly, but it looks like itâs working!
DNSCrypt provides secure DNS today, whereas neither of the secure services offered by Cloudflare have been implemented by Apple in macOS or Safari yet. As far as I know, the same is true for all 3rd party Mac browsers.
-Al-
To use DoT encryption your link to the instructions for installing stubby include this snippet:
- address_data: 9.9.9.9
tls_auth_name: âdns.quad9.netâ
tls_pubkey_pinset:
- digest: âsha256â
value: MujBQ+U0p2eZLTnQ2KGEqs+fPLYV/1DnpZDjBDPwUqQ=
If Iâm using CloudFlare, do I need to change the 9.9.9.9 to 1.1.1.1 and âdns.quad9.netâ to some thing else?
Of course this all gets interesting if you set your DNS on the local device (laptop, phone, âŚ) then try and connect via a WiFi that wants you to agree to some terms. Some (many) of them black hole all of your traffic until you ask for a web page. Then they put up their âcheck this boxâ or âlog in with your credentialsâ page. They do this by re-directing all your DNS requests to the device they give you via DHCP to their internal authentication whatever. So email and web browsing just hang or gives odd errors until you turn off your custom DNS settings and then get the authorization page to load or reload. (If you browser fired up with those 3 windows and 40 tabs have fun finding the web page you need.) More and more authentication setups are getting better about making this all work without the hassles but the annoying ones are still plentiful.
And my wife is asking, âwhy canât it just workâ as we are in some airport concourse for the first and maybe only time in our lives.
David
Iâm trying to test Cloudflare DoT encryption over Google Fiber using âstubbyâ. I keep getting the message âCould not bind on given addresses: Address already in useâ. Any idea what I might be doing wrong? Thanks
Stephen
Found my problem.
If the stubby daemon is running before I run a test, I have to kill it in Activity Monitor each time before I run it.
I also found that it will work with or without the tls_pubkey_pinset parameter.
Researchers have found some Chrome VPN extensions leaking DNS infoâŚ
