Continuing the discussion from Back up drives:
Beginning now, in anticipation of @ace moving other people’s replies…
Absolutely correct, but…
You can’t incrementally update the system volume. So if you want to keep that volume up to date (e.g. after a macOS upgrade), you need to redo a complete backup, which will blow away your backup history (e.g. all the incremental backups on the data volume), and will take a long time to complete.
I would suggest that if you go this route, you make it just once, and from that point forward, only make incremental backups of the data volume. The system volume may drift out of sync, but it should remain bootable, so you can use it for a quick recovery, should that become necessary, but without losing your history of incremental backups.
Maybe redo the full backup after a major upgrade (e.g. from Sonoma to Sequoia), if you are concerned that the upgrade may make changes to the data volume incompatible with the old system, but no more often than that.
Also note that Apple and people like Mike Bombich have said that this capability is not guaranteed to work, and may break in the future. So you should probably still plan for recovering the way Apple would like (use Recovery to make a clean install of macOS, then the Migration tool to restore all your content from a Data volume backup).
Yes and no. Yes, they have to deal with it, and yes, they have.
But the ASR utility is still mostly undocumented, so it may break in the future. And it can not perform an incremental backup - it always wipes the target APFS container. So it’s much less useful than bootable backups were before the creation of the SSV.
