BBEdit 15.5.2
Originally published at: https://tidbits.com/watchlist/bbedit-15-5-2/
Bare Bones Software has released BBEdit 15.5.2, a maintenance update for the venerable text editor. The update fixes a bug where “Match using pattern” for Process Duplicates did not work as intended, resolves a crash that would occur when switching appearances, addresses misbehavior when using the Quit command from the Dock menu, fixes a bug in which certain uses of character classes in a grep pattern would fail to match during a multi-file search, adds some additional content types to the list of system-exported types that BBEdit recognizes as text files, and improves compatibility with future macOS versions by using a system-provided image for the “swap” button in the Find, Multi-File Search, and Find Differences windows. ($59.99 new, free update, 28.3 MB, release notes, macOS 12+)
