Originally published at: https://tidbits.com/watchlist/audio-hijack-4-6/
Rogue Amoeba has updated Audio Hijack 4.6 (full-featured audio recording), Piezo 1.9.10 (simple audio recording), and SoundSource 6.1.2 (audio control utility) with preliminary support for the macOS 27 Golden Gate public beta. While the apps no longer warn you on launch when running Golden Gate, Rogue Amoeba encourages sticking with non-beta macOS releases for the best app experience.
Audio Hijack also enhances the built-in Transcribe block with a new Recommended transcription model, supports Yandex Telemost as a VoIP audio source, and correctly disables certain menu options when a recording is in progress. SoundSource also receives several AirPlay enhancements (including more reliable auto-connection to AirPlay devices), optimizes silence processing to help reduce CPU usage, ensures multiple sources no longer appear for the same process, and no longer incorrectly doubles audio when previewing media with Quick Look in the Finder. (Audio Hijack, $69, 27 MB, release notes, macOS 14.4+; SoundSource, $49, 55.6 MB, release notes, macOS 15+; Piezo, $29, 12.5 MB, release notes, macOS 14.4+; all have a 20% discount for TidBITS members and are free updates)
