Apple Introduces Studio Display XDR and Refreshes Studio Display
Originally published at: Apple Introduces Studio Display XDR and Refreshes Studio Display - TidBITS
Four years after its initial release, Apple has refreshed its Studio Display and introduced a new model—the Studio Display XDR—that replaces the $5000 Pro Display XDR while lowering the entry price for professional-grade display technology. Both displays bring significant improvements, but the Studio Display XDR is the bigger story, delivering mini-LED technology and HDR capabilities at a price point that makes them accessible to a much broader range of professionals.
Apple Studio Display and Studio Display XDR
Studio Display: Evolutionary Improvements
The updated Studio Display retains the same 27-inch 5K Retina display (5120-by-2880 at 218 ppi) that made the original popular, but Apple has upgraded several key components that matter for daily use:
  • Better Camera and Connectivity: The most notable upgrade is the Studio Display’s camera system. Apple has replaced the 12-megapixel Ultra Wide camera with the 12-megapixel Center Stage camera, presumably the same one found in the iPad Pro, iPad Air, MacBook Air, and MacBook Pro. Although the grumbling died down over time—perhaps due to improvements delivered via firmware updates, perhaps due to exhaustion—early Studio Display users weren’t happy with its picture quality. The new camera also supports Desk View, the feature that simultaneously shows you and a top-down view of your workspace during video calls.
  • More Thunderbolt 5: The Studio Display moves from one Thunderbolt 3 port and three USB-C ports to two Thunderbolt 5 ports and two USB-C ports. The jump to Thunderbolt 5 is substantial, providing up to 120 Gbps of bandwidth compared to the previous 40 Gbps. The additional bandwidth means you can now daisy-chain up to four Studio Displays or attach high-performance accessories. The rightmost Thunderbolt 5 port marked with a dot provides 96W of host charging power.
    Studio Display ports
  • Enhanced Audio: Apple claims the six-speaker system now delivers 30% deeper bass than the previous generation, thanks to redesigned force-cancelling woofers.
The Studio Display starts at $1599 with a tilt-adjustable stand, the same price as the original model. You can still configure it with nano-texture glass ($300), a tilt- and height-adjustable stand ($400), or a VESA mount adapter (no additional cost). Stand options must be chosen at purchase and aren’t interchangeable without Apple-authorized service.
Speaking as someone with a pair of the original Studio Displays, I can’t see any reason to upgrade, and I’m not sad that I bought before this new model came out. Those who are unhappy with the video quality of the original Studio Display have probably already purchased a better webcam, and people who need lots of Thunderbolt 5 bandwidth have probably already addressed it with a Thunderbolt dock. Plus, I can’t imagine Desk View being important to that many people. But for anyone buying today, the improvements are welcome.
Studio Display XDR: Pro Display Tech for Less
Here’s where things get interesting. With the Studio Display XDR, Apple has effectively taken the technology from its now-discontinued $5000 Pro Display XDR, modernized it, and brought it to market at $3299—a huge price reduction that puts professional-grade HDR display technology within reach of a larger audience.
Much of that cost savings likely comes from panel size. The 27-inch 5K panel is more common (and thus cheaper to source) than the Pro Display XDR’s 32-inch 6K panel, which almost certainly never achieved economies of scale. Like the standard Studio Display, the XDR version includes the 12-megapixel Center Stage camera with Desk View, the studio-quality three-mic array, and the immersive six-speaker system with Spatial Audio support. It also features Thunderbolt 5 connectivity with 140W of charging power—enough for a 16-inch MacBook Pro.
Here’s what sets the Studio Display XDR apart:
  • Industrial design: Physically, the Studio Display XDR looks similar to the Studio Display, though its additional hardware makes it slightly deeper and noticeably heavier. The Studio Display XDR comes standard with the tilt- and height-adjustable stand (the $400 upgrade on the regular Studio Display), offering 105 mm of height adjustment with a sophisticated counterbalancing arm. A VESA mount adapter is available at no additional cost, and when VESA-mounted, the display can be rotated to portrait orientation. As with the regular Studio Display, the stand choice is permanent unless you pay an Apple Authorized Service Provider to change it.
  • Backlighting tech: What most sets the Studio Display XDR apart is its 27-inch 5K Retina XDR display with mini-LED backlighting using 2,304 local dimming zones to deliver extreme contrast. The Studio Display XDR’s 2304 dimming zones are a 4x increase over the Pro Display XDR’s 576 zones, which should mean better contrast and less blooming.
  • Brightness: The Studio Display XDR delivers up to 1000 nits of sustained SDR brightness, 2000 nits of peak HDR brightness, and a 1,000,000:1 contrast ratio. In comparison, the standard Studio Display has only 600 nits of brightness, and the Pro Display XDR has 500 nits of SDR brightness and 1600 nits of HDR brightness. In other words, the Studio Display XDR can sear your eyeballs, in a good way.
  • Color accuracy: In a spec that will be appreciated by print and design professionals, the Studio Display XDR supports both P3 and Adobe RGB wide color gamuts, streamlining workflows that frequently switch between color spaces.
  • 120 Hz and Adaptive Sync: Unlike its predecessor, which maxed out at 60 Hz, the Studio Display XDR offers a 120 Hz refresh rate, with Adaptive Sync supporting variable refresh rates from 47 Hz to 120 Hz. The higher refresh rate makes the display more responsive for video editing and even gaming, should you be so inclined.
In an interesting expansion of the display’s capabilities, Apple has introduced DICOM medical imaging presets that, once the Medical Imaging Calibrator app receives FDA clearance, will allow radiologists to view diagnostic images directly on the Studio Display XDR. In terms of raw display capability, the comparison with common radiology hardware is striking: the Studio Display XDR’s 5K panel (5120 by 2880, or nearly 15 megapixels) exceeds the resolution of many more expensive diagnostic radiology displays, which are often only 3–6 megapixels. For context, specialized diagnostic radiology displays typically cost $5,000–$10,000 for just 3–6 megapixels of resolution on smaller screens. The Studio Display XDR’s 15-megapixel panel in a larger format looks like a bargain, once Apple gets FDA clearance.
Studio Display XDR with radiology example
Few Pro Display XDR owners will likely switch to the Studio Display XDR. While it has some improved specs, it’s still significantly smaller—who’s going to give up a 32-inch 6K display for a 27-inch 5K display?
But on its own, the Studio Display is important. By bringing mini-LED technology, HDR support, and professional color accuracy to a 27-inch display at $3299, Apple has made these capabilities accessible to video editors, photographers, and designers who couldn’t justify the cost of the $5000 Pro Display XDR, particularly when coupled with the $1000 Pro Stand. Yes, $3299 is still expensive, especially when you add $300 for nano-texture glass. But for many professionals whose work demands accurate color reproduction and HDR preview capabilities, the Studio Display XDR is a far better value than the Pro Display XDR it replaces.
Compatibility and Availability
Both displays require macOS 26.3.1 Tahoe or later and work with all Apple silicon Macs. So if you want to buy one of these displays, you’ll have to upgrade to Tahoe and its controversial Liquid Glass interface redesign.
The Studio Display XDR supports 120 Hz only on newer Macs with M4 and M5 chips; older models (M1 through M3) are limited to 60Hz, though all other features work. Both displays also work with recent iPads running iPadOS 26.3.1 or later, including iPad Pro and iPad Air models that have USB-C ports.
The same $1599 base price for the same 5K panel they introduced all the way back in 2014. What a missed opportunity. And they still consider a proper adjustable stand just another source of extra income. This from a company that used to pride itself on ergonomics. :frowning:
Dang, that XDR is something to consider if I get a bit lucky this year.
I have a Studio Display and had been planning, sometime, on another. So the XDR would be a big increase but… maybe…
Notice that it’s only $200 less than a Vision Pro.
Is the Adaptive Sync ‘up to 120Hz’ fully compatible with Nvidia and AMD video cards? If so, while expensive, the Studio Display XDR would be one of the few ways to have a single monitor run at 5K on the Mac side and also allow gaming in 4K (or lower res) at high refresh rates on a PC.
This is still highly underwhelming for the majority of Apple users. And the forums on various Apple sites have longterm users pretty fuming at both displays offerings at prices that make no sense. And quite rightly so, IMO.
The upper model may have fancier tech for a few handfuls of medical professionals to use, but the features look added just as an excuse to have a higher model, rather than things the majority of pro and prosumer users would find worth buying at such a price. They even only offer the vesa option at the same price as the one with a fully featured stand – the same stand they charge $400 extra for on the cheaper model! Ridiculous.
As for the cheaper model, in 2026, charging $1600 for the same 5K panel type they introduced back in 2014 for almost no spec interested worth mentioning, is frankly ludicrous. It’s like Apple doesn’t see prices in the current marketplace for other 5K and 6K displays, with the improved styling on some (eg. LG 6K UltraFine). They think they can command some silly higher price constructed outside reality, which may wash with some, but not with savvier buyers.
In 2006 I purchased the 20" Apple Cinema Display (ACD) for $735. Adjusting for inflation that would be $1175 today – for a 20" monitor. Spending $1599 for a 27" Apple Studio Display (ASD) sounds like a good deal to me.
I was still using my 20" ACD on my M2 Apple Studio until I replaced it with the 27" Apple Studio Display.
$735 (or, if you will, $1175) amortized over 19 years is a pretty good value.
If I did not already have an Apple Studio Display I would buy one now.
Sure, if you simply must buy Apple. But there arguably better options out there that cost considerably less.
When I bought my two current Apple ones on their release in 2022, good options were not there, but things have changed in the marketplace and now there are.
Why do you find it necessary to argue with me about my choice?
I meant if anyone must buy Apple, not you individually.
I’m an amateur photographer looking for a new monitor. The new Apple Studio Display is essentially the same price as a QBen 4K 27 inch monitor. Which one would you recommend I buy? I’m inclined towards the Apple Studio Display since it would play nice with my MacBook M1Pro
If the Apple Studio Display is within your spending ballpark, don’t consider 4K at 27". They go for far far less (like $300 for this 27" Dell 4K.)
If you want a quality 27", you want a 5K screen (5120x2880) so you get ~220 ppi which is clean x2 Retina for the ~110 ppi standard resolution for Apple these days. The Apple Studio Display is 5K because of that. It leaves you with a nice crisp image and no scaling fuzziness.
But the Apple Studio Display is also very expensive, and even more so if you’d also like a properly adjustable stand or a non-glossy panel. Furthermore, if you want a second input to be able to display for another computer in addition to your primary Mac, it leaves you plugging and unplugging because it has only a single input. OTOH, if you value the built-in camera and speaker system, other manufacturers’ 5K offers will likely leave you not quite as satisfied.
I personally want non-glossy, multiple inputs, and for me a properly adjustable stand is mandatory. I don’t care about camera or speakers. So I went with an Asus 5K ProArt 27" that I really like (I’m colorblind and I do science not creative, just FTR). At $729 it’s far less expensive than the ASD with adjustable stand and nano texture ($2299). Even a refurb is $1829, 2.5x as expensive.
Edit 1: And just for completeness, there are other 5K panels from 3rd parties that sell for substantially less than the Apple Studio Display. These two come to mind (but I don’t have any personal experience with them). Both are around $1k.
Edit 2: I just remembered, if indeed somebody is looking to spend almost $2k on an Apple Studio Display, I think $1900 for this 6K 32" (also matched for 220 ppi) is likely a much better deal. Unless of course 32" is out of the question and it has to be 27". In that case 5K and something like the Asus above is IMHO the way to go.
As someone currently in the market for a 32-inch 6K monitor, Apple’s elimination of a 32-inch monitor was surprising. Luckily, at least three non-Apple 6K monitors are available, at reasonable prices, which possibly explains Apple’s exit from this part of the monitor market. Thanks for the article Adam.
Great info on the current marketplace alternatives, and further background on the somewhat disappointing nature of Apple’s new display offerings (they’re good, but expensive compared to other similar ones).
That LG 6K Ultrafine is perhaps the best IMO, provided the person doesn’t mind that price-point and/or wants TB5 connection.
There’s also an older TB4 Asus ProArt Display 32” 6K – though you certainly do pay a lot more for that ‘extra 1K’ (which is actually ~25% more screen space) over its 27" 5K cousin ($570: 1300-730):
Not sure on the technical details myself, but another point about Apple’s choices on their higher-end display come from some commentators who have said that Apple moved the higher model down to 27" (5K) in order to offer hi-res 220ppi at 120Hz (and perhaps the other specialist features it also has), because 6K’s couldn’t support the bandwidth.
But surely TB5 offers a massive 80/120Gbps of bandwidth, and/or DSC (Display Stream Compression) could be used, so can’t fathom that being wholly true here. Alternatively, it could also be that its daisy-chaining options would have been compromised on a 32" 6K 120Hz. So who knows?
Personally, I just feel that Apple’s usual marketing story they tell about why this or that product is so great, fails to hit on these displays – as evidenced, rightly or wrongly, by the largely lacklustre media and punter response to them. Oh well… maybe when 8K/10K becomes a computer monitor thing in say another 4 years, people may get more excited again or something! :slight_smile:
Another 32-in 6K monitor not often mentioned is the Kuycon ( Sales Web Page ) review here: YouTube Review
The Kuycon resembles Apple’s monitors which undoubtedly isn’t coincidental.
Jason Snell has a nice review of the new Studio Display. The main thing I was taken by is that it apparently has an A19 chip, which means that it has more memory and computing power than a MacBook Neo. What would be necessary to turn it into a 27-inch iMac Neo beyond some storage? $1600 for that seems like a steal.
I have been waiting for a Studio Display with mini LED to match the display of my recently acquired MacBook Pro M4 Pro, but that appears to not be happening now :worried: The Studio Display XDR does seem to fit what I want (mini LED, P3 and Adobe RGB), and although expensive I can afford it. But then I read this:
Why? Apple does not want my money?
I do not want to ‘upgrade’ to macOS 26 yet (eventually I’ll probably have to). So I guess I’ll keep using my Eizo 24” display a bit longer, it still does the job reasonably well, good enough for my purposes as an amateur photographer.
Because Apple doesn’t want to release the necessary support software for older operating systems and increase the size of the test matrix for the rest of the life of these displays.
