Originally published at: AppBITS: TrackWeight Turns Your Trackpad into a Scale (Sort Of) - TidBITS
At the beloved MacHack conference of yesteryear, the main event was always the MacHax Best Hack Contest (don’t ask about the different spelling). For their contest entries, some of the top Mac programmers would stay awake for up to 72 hours straight coding. On the final day of the conference, everyone would gather in an auditorium as developer after developer showed off their hacks. Audience reaction was enthusiastically chaotic, with hacks that aimed to improve the overall Mac user experience often being met with derisive cries of “Useful!”
In 1999, Lisa Lippincott’s Unfinder won first place despite facing numerous catcalls, since it was the first time we saw Undo available for non-destructive actions in the Finder, such as moving files; see “The MacHack Hack Contest 1999,” 12 July 1999. (In contrast, asciiMac, the 1998 winner from Alexandra Ellwood and Miro Jurisic, converted the entire Mac interface to ASCII graphics in real time, which no one mocked as useful; see “Moof on the Hoof: MacHack ’98,” 6 July 1998.)
All that’s by way of introducing a new Mac app that would have fit in perfectly at MacHack: TrackWeight, which turns the Mac’s trackpad into a precision scale for weighing small objects. On the face of things, this would seem like a handy feature, but the technical requirements for implementing TrackWeight make it the perfect MacHack novelty app. The problem is that trackpad pressure events are generated only when capacitance is detected on the trackpad surface—in other words, your finger or another conductive object must be in contact with the trackpad. When that’s the case, the trackpad’s Force Touch sensors provide pressure readings that can be calibrated and converted into weight measurements.
It’s nearly impossible to rest your finger on the trackpad, press the Space bar to calibrate, and then add something else to the trackpad to weigh it without changing the pressure applied by your finger. It can be done—I glimpsed a few correct weights while testing—but I spent vastly more time failing to get accurate measurements than succeeding. Neither a pen with a conductive nub nor a plum—both of which could control the pointer—provided a stable weight and conductivity.
I’m rooting for TrackWeight’s developers to figure out a workaround for the required finger pressure so the app becomes actually useful, but until then, it’s mostly an inspired hack that would have earned applause from the MacHack crowd.
