After hearing about a few instances where our email (both mine and Tonya’s personally, and transactional and bulk mail from our systems) wasn’t being delivered properly, I dove into my SPF, DKIM, and DMARC setup. I think I’ve done everything right, and checkers all claim that I have, but I’m still seeing some problems.
SPF: https://easydmarc.com/tools/spf-lookup?domain=tidbits.com
DKIM: https://easydmarc.com/tools/dkim-lookup?domain=tidbits.com
DMARC: https://easydmarc.com/tools/dmarc-lookup?domain=tidbits.com
A few of the problems are probably impossible to avoid, since if someone at cornell.edu forwards their email to a Gmail address, for instance, mail from me will fail authentication because I don’t have cornell.edu allowed to send tidbits.com mail. If SPF allowed more than 10 lookups, I might special-case a few domains like cornell.edu, but I’m already having to specific IP addresses manually to get around the 10-lookup limit.
Where I get worried, though, is when I look at reports. For instance, Cloudflare shows only 93% of email sent through Gmail and 72% sent through Microsoft has passing DMARC. (I’m not even sure what tidbits.com mail gets sent through Microsoft, since Tonya and I both use Gmail as the backend of our tidbits.com accounts.) Maybe it’s just forwarding, but if not, that’s 20 failed messages through Gmail and 60 through Microsoft in a week. That’s a lot, and it’s hard to know when a message you send doesn’t arrive. Even with Amazon SES, which handles most of our outgoing bulk and transactional mail, the .32% failure rate works out to over 1300 failed messages in the week.
But why do Amazon and Google fail SPF when I have them included in my SPF record with include:_spf.google.com and include:amazonses.com?
v=spf1 ip4:64.68.200.0/22 ip4:64.68.200.41 ip4:64.68.198.23 ip4:64.68.203.22 ip4:64.68.198.24 ip4:64.68.200.59 ip4:64.68.200.63 ip4:205.201.128.0/20 ip4:198.2.128.0/18 ip4:148.105.8.0/21 ip4:64.62.152.51 include:easymail.ca include:_spf.google.com include:amazonses.com include:mailchannels.net ~all
And then I get this report from Postmark DMARC, and the only thing I can pull out as an actionable item is perhaps setting up a Return-Path with Amazon SES. But that gets into MX record juju, which I really don’t want to mess up. And other stuff I just don’t understand, such as how just a couple of IPs at google.com can fail DKIM—if I’ve set it up correctly, how can it fail for just a few? Similarly, Postmark DMARC claims that easyDNS’s 64.68.200.41 server is failing SPF, but it’s explicitly listed in my SPF record with ip4:64.68.200.41. Augh!
Anyone have any experience with SPF, DKIM, and DMARC that would provide insights into what’s happening here? Thanks!
Your sources
These are sources that we know belong to you based on the DNS checks we do.
amazonses.com
TOTAL SPF ALIGNED DKIM ALIGNED 54.240.11.69 509 0% 99.8% 54.240.8.32 505 0% 100% 54.240.10.1 503 0% 100% 54.240.11.44 503 0% 100% 54.240.11.60 503 0% 100% 43 more IPs 19,891 0% 99.8% amazonses.com is authorized to send on behalf of tidbits.com, however it looks like SPF is still failing DMARC’s alignment test. DMARC looks at the Return-Path of a message to make sure the domain there matches the domain in your From address. If the Return-Path path doesn’t match your From address, those messages will fail DMARC’s SPF alignment test. Check with this source because you may need to set up a custom Return-Path. google.com
TOTAL SPF ALIGNED DKIM ALIGNED 209.85.220.41 560 0% 98.2% 209.85.220.69 9 11.1% 0% 209.85.220.97 5 0% 100% 209.85.128.172 2 0% 100% 209.85.128.177 2 0% 100% 90 more IPs 106 0% 98.1% easydns.com
TOTAL SPF ALIGNED DKIM ALIGNED 64.68.202.10 128 100% 0% 64.68.200.41 123 0% 76.4% Not Resolved
TOTAL SPF ALIGNED DKIM ALIGNED 64.62.152.51 8 0% 0% 192.92.191.183 2 0% 0% 170.158.12.141 1 0% 0% 185.218.11.138 1 0% 0% 192.92.191.182 1 0% 0% 4 more IPs 4 0% 0% Not Resolved is authorized to send on behalf of tidbits.com, however it looks like SPF and DKIM are still failing DMARC’s alignment test. DMARC looks at the Return-Path of a message to make sure the domain there matches the domain in your From address. If the Return-Path path doesn’t match your From address, those messages will fail DMARC’s SPF alignment test. Set up a DKIM record and check with this source about setting up custom Return-Path.
mailchannels.net
TOTAL SPF ALIGNED DKIM ALIGNED 23.83.209.13 1 0% 100% 23.83.209.150 1 100% 0% 23.83.212.19 1 100% 0% 23.83.212.4 1 100% 0% 23.83.212.50 1 100% 0% 4 more IPs 4 100% 0% zoneedit.com
TOTAL SPF ALIGNED DKIM ALIGNED 64.68.198.23 6 0% 100% 64.68.198.24 2 0% 100% zoneedit.com is authorized to send on behalf of tidbits.com, however it looks like SPF is still failing DMARC’s alignment test. DMARC looks at the Return-Path of a message to make sure the domain there matches the domain in your From address. If the Return-Path path doesn’t match your From address, those messages will fail DMARC’s SPF alignment test. Check with this source because you may need to set up a custom Return-Path. easydns.net
TOTAL SPF ALIGNED DKIM ALIGNED 64.68.203.22 5 0% 100% easydns.net is authorized to send on behalf of tidbits.com, however it looks like SPF is still failing DMARC’s alignment test. DMARC looks at the Return-Path of a message to make sure the domain there matches the domain in your From address. If the Return-Path path doesn’t match your From address, those messages will fail DMARC’s SPF alignment test. Check with this source because you may need to set up a custom Return-Path. easymail.ca
TOTAL SPF ALIGNED DKIM ALIGNED 64.68.200.59 3 0% 100% 64.68.200.63 1 0% 100% easymail.ca is authorized to send on behalf of tidbits.com, however it looks like SPF is still failing DMARC’s alignment test. DMARC looks at the Return-Path of a message to make sure the domain there matches the domain in your From address. If the Return-Path path doesn’t match your From address, those messages will fail DMARC’s SPF alignment test. Check with this source because you may need to set up a custom Return-Path. Other sources
These sources are sending emails saying they are from tidbits.com, but we couldn’t verify that they belong to you. It’s important to go through each source and set up SPF and DKIM records for sources that you control.
maaat.com
TOTAL SPF ALIGNED DKIM ALIGNED 23.239.4.200 44 0% 0% Use the API to fetch the 23 remaining domains. Forwarded email sources
These sources might be from forwarded emails. The email headers are often preserved when emails are forwarded causing DKIM to pass and SPF to fail DMARC alignment because the From address no longer matches tidbits.com’s SPF record. Generally, there’s nothing to worry about if you already have SPF and DKIM set up on your sources.
Learn more about forwarded sources →
me.com
TOTAL SPF ALIGNED DKIM ALIGNED 17.58.23.191 31 0% 100% 17.58.23.183 28 0% 100% 17.58.23.193 25 0% 100% 17.58.23.182 23 0% 100% 17.58.23.188 23 0% 100% 85 more IPs 565 0% 100% cornell.edu
TOTAL SPF ALIGNED DKIM ALIGNED 3.224.229.126 178 0% 0% 128.253.150.158 21 0% 28.5% outlook.com
TOTAL SPF ALIGNED DKIM ALIGNED 2a01:111:f400:7eae::700 4 0% 75% 2a01:111:f400:7eae::601 3 0% 100% 2a01:111:f400:7e8a::613 2 0% 100% 2a01:111:f400:7e8b::617 2 0% 50% 2a01:111:f400:7eae::600 2 0% 100% 119 more IPs 120 0% 62.5% pobox.com
TOTAL SPF ALIGNED DKIM ALIGNED 173.228.157.40 16 0% 100% 173.228.157.39 15 0% 100% 64.147.108.55 15 0% 100% 64.147.108.50 14 0% 100% 64.147.108.51 12 0% 100% 3 more IPs 26 0% 100% umich.edu
TOTAL SPF ALIGNED DKIM ALIGNED 52.37.117.118 13 0% 100% 13.58.214.35 11 0% 100% 18.219.197.222 11 0% 100% 18.188.205.92 10 0% 100% 35.160.237.124 10 0% 100% 2 more IPs 9 0% 100% elnk.net
TOTAL SPF ALIGNED DKIM ALIGNED 24.41.67.42 21 0% 100% 24.41.67.41 18 0% 100% 1e100.net
TOTAL SPF ALIGNED DKIM ALIGNED 2600:1901:101::11 19 0% 100% 2600:1901:101::10 15 0% 100% 108.177.16.12 1 0% 0% 108.177.16.13 1 0% 100% 2600:1901:101:: 1 0% 100% 1 more IP 1 0% 100% yahoo.com
TOTAL SPF ALIGNED DKIM ALIGNED 74.6.132.42 3 0% 100% 74.6.128.205 2 0% 100% 74.6.135.82 2 0% 100% 66.163.184.147 1 0% 100% 66.163.186.206 1 0% 100% 25 more IPs 25 0% 100% comcast.net
TOTAL SPF ALIGNED DKIM ALIGNED 2001:558:fd00:56::b 2 0% 100% 2001:558:fd01:2bb4::4 2 0% 100% 2001:558:fd01:2bb4::d 2 0% 100% 2001:558:fd02:2446::3 2 0% 100% 2001:558:fd02:2446::8 2 0% 100% 19 more IPs 21 0% 100% Use the API to fetch the 230 remaining domains.
