When you check your Account: on the Dropbox site > avatar (upper right corner) > Manage account > Personal Dropbox space
what does it report on number of devices connected? Under Manage Account what is the breakdown of storage being used? mine for example is:
Personal Dropbox space Using 2.5 GB of 5.88 GB
Regular files (1.3 GB)
Backup (0 bytes)
Shared files (1.2 GB)
Unused space (3.3 GB)
AirDrop on Sonoma has gotten rather wacky. It can see the ghosts of a couple of old macs that bit the dust earlier this year, but my wife and I have having trouble using it between our newer devices even when they are in the same room. Does anybody have a remedy?
Regarding the response recommending Mail Drop… I find it unreliable. Half the time it doesn’t engage (and there’s no way I’m aware of to manually engage it).
Part of Dropbox’s business model is pushing people to upgrade to paid plans. One alternative is to turn off Dropbox notifications.
@openreels is right, a shared Dropbox folder does count against your total storage tally
I think that it is worth contacting Dropbox support if the software is saying that you are over the 2 GB limit when you are not.
As others have suggested, there are numerous free/nominal cost alternatives, including Microsoft OneDrive, Google Drive, and iCloud Drive, along with more specialized tools.
I do a fair amount of consulting. In practice, that means I need to use all of the major platforms at least occasionally. I can’t say that any of the major players are much better or worse than the others. It’s mostly a matter of getting used to how they work.
As most of the major platforms have been converging on using Apple’s “Storage Provider” APIs for managing cloud syncing, the differences between platforms have been decreasing. FWIW, my preferred platform is Dropbox, and I have found it to be rock solid. I do pay for the 2 TB Dropbox Plus plan, so my exerience may be different from yours.
