Ideally yes, but we have no idea what other new code might be added for entirely legitimate reasons. Or it could be a complex interaction with some other system that was triggered by a date. Just too many unknown variables.
I think that’s smart—BusyCal and FantastiCal are worlds better than Apple’s Calendar. However, they’re still getting the data from iCloud Calendar or Google Calendar or wherever. That’s usually fine, but it means they’ll show exactly the same data as Apple’s Calendar.
Thanks for all the notes with respect to BusyCal, syncing, etc.
I will survive the Calandar/Contacts situation.
On a different topic, getting back to the article from Adam, which got this thread going, could someone post a note to this thread, indicating that most probably, Apple has fixed this bug? (Adam did suggest this sort of response, in the original article.)
(Referring to the Apple bug which was forcing some people running Monterey or Ventura, to upgrade to Sonoma without permission.)
Frankly I feel that the efforts to force an upgrade is not entirely by accident or bug. When calling Apple Support with any Ventura related issue or Apple App issue the very first thing they try to do is attempt to get me to upgrade to Sonoma. They have refused to help me with some issues unless I first upgrade. I suspect that one of the reasons is that Sonoma sunsetted some features that they no longer wish to support. The two that disturb me in particular and would interfere with my usage is the removal of Apple Mail plug-ins and the removal of the ability to do searches that include Apple Mail from third party Apps such as HoudahSpot. Those are some of the primary reasons I do not want Sonoma. I am also of the opinion that Sonoma sort of dumbs down macOS from the user’s perspective making it more difficult to configure it to a user’s needs and desires. I regard this to be part of their attempt to evoke a refrigerator mentality to Macs along with what seems to be their long-term goal to merge macOS with iOS and to coerce users to use more subscription services in order increase the already outrageous compensation for management executives. I consider Apple to be two companies: the old Apple before Tim Cook that was focused on the customer experience and the new Apple under Tim Cook focuses on maximizing profit over the user experience by turning Apple into a prestige upper class status symbol. As for me, I want a computer that I can configure to do the tasks that I want it to do in the way I want to do them that is extremely reliable and of good value, rather than a piece of technology art to be placed on display as a status symbol.
Let’s stay on the topic of the Monterey/Ventura bug that causes the unwanted upgrade, not general complaints about Sonoma or Apple.
Any further divergences will be deleted summarily because I’m utterly sick of them—it’s what I like least about the Apple community these days and is the thing most likely to drive me away from participating in it. If you don’t have anything constructive to say, don’t say anything.
I got bit by the upgrade bug too (MBP 2018, Intel, Ventura). I had seen something that looked like a tiny bit of an upgrade dialog a while ago (on January 10?) but nothing ever came of it… until today, when I rebooted and discovered that the Sonoma upgrade that you wrote about earlier this week was coming to pass. I guess I clicked the X box on the dialog which triggered the upgrade. It never asked me to reboot… I guess it was waiting quietly to pounce.
My copy of BBEdit now fails, so I’ll need to upgrade. But at least my copies of VMWare Fusion and Parallels Desktop are working so far (both Windows 10 VMs), so maybe they’ve fixed the bugs with Parallels Desktop (I have v19.2.1).
Howard Oakley (@ace linked to it just above) also quoted that command. However, in his article he makes quite clear that there’s a big question mark you can fully prevent unwanted Sonoma force updates just by stopping macOS from displaying the upgrade nag (which is what that command does).
If those forced upgrades had been initiated independently of that notification, as some accounts imply, then blocking its appearance wouldn’t have prevented the upgrade from occurring.
This confirms that posting the Upgrade to macOS Sonoma notification is but the final step in extensive preparations to start the upgrade. If forced upgrades that took place in the middle of January did occur without the user interacting with that notification, then it suggests that blocking the appearance of the notification may not be effective in the event of a repetition of this or a similar bug.
And, I just discovered that my Software Updates prefs have been changed from
√ Check for updates
√ Install System data files and security updates
to:
√ Check for updates
√ Download new updates when available
So Sonoma is lurking somewhere on my drive (AGAIN).
But now it is all unchecked and I’m counting on SilentKnight.
There is a story of DAYS lost restoring my working partition (which along with my Time Machine and every volume on my machine other than the HFS+ spinner was corrupted by following the advice of I-am-sure-were-well-meaning-persons (but against my expressed concerns).
But I am too F’ing exhausted by the wasted time. Good thing I am retired, some one might have gotten “offended” at the least.
…later…FWIW, I couldn’t find any trace of Sonoma, but…
I have read this post and others with interest because it appears that the issue is unresolved in subsequent macOS.
I have an OP (Original Poster) on another forum I contribute to who has exactly the same problem on an M2 MBP with Sonoma updating/upgrading to Sequoia despite all automatic updates being disabled in System Settings > General > Automatic Updates He also has Security Updates turned off.
As it was a one off I suggested he reset his preferences which he did and wait until the next Sequoia update 15.0.1
He did this and reported back that despite his “best efforts” to prevent it a couple of days after the update was released he received a dialogue box stating that his Mac “would restart in 40 secs to instal updates.”
I would dearly love to advise this guy but am at a loss to suggest a fix. Currently, short of suggesting a “clean” instal of Sequoia to remove all traces of Sonoma, something the OP is clearly reluctant to do, I am stumped.
