Try the Activity Monitor in the Systems–Utilities folder; it’s quicker to find it in Spotlight. It will show you all the apps you’re running along with the systems stuff that’s running in the background so you can see what applications are hogging memory. Activity Monitor has helped keep me chugging along with my very elderly MacBook Pro. One example is that l use Time Machine for backups, and I didn’t remember when it was running.
It’s easy to use, but if you’re not very technically inclined like me, the info at Apple support is very helpful, esp. about stuff that runs in the background:
A quicker way (IMHO) to get there is press F4 (Launcher) and type AC, you’ll be there.
I run the activity monitor all the time. It launches at startup and I keep it as the rightmost App in the dock. Seldom need to look at it but when something goes awry, it’s instantly available and it really does make it a lot easier to figure out what the issue is.
Most of the time i have the CPU tab active but it cane revealing to look at the others, just give them a few seconds to gather data and populate the display.
If you can’t find any runaway processes, get a utility such as Volitans Smart Utility that can talk to the disk drive and see if it’s getting errors. The drive is old enough that it could well be failing, and the first symptom of that is usually a general slowdown as the drive keeps trying on bad blocks until it finally succeeds. These ‘temporary’ errors do not get reported to the operating system, and that SMART Verified yes/no thing is absolutely useless. By the time it says ‘no’ the data is usually not recoverable.
Volitans isn’t free, but has a free demo period. It’s well worth paying for though. It can watch the disk in the background and warn you when trouble starts, which has saved my bacon several times over the years. Unfortunately, external drive enclosures rarely pass SMART data; if you manage to find one that does, hang onto it so you can test externals, too.
If the drive is bad, get a ‘final’ bootable backup, then replace it. For an iMac, the easiest thing is to run from an external drive though it’s slower, which may or may not be noticeable depending on what you’re doing. If the internal drive is really bad, it can keep everything slow when it’s mounted (the system periodically tries to talk to any drive it sees). You can test this by dismounting the drive by hand. If letting it stay mounted causes slowdowns, you can put in a cron job or automator action to dismount it automatically on startup.
If your Macintosh has run just fine with 8GB of RAM in the past, it’s not suddenly your problem now. My guess, after 6 years, is that your hard drive may be dying. Try running Disk Utility/First Aid to see if that helps.
This will spur me on to purchase that new iMac for my better half. Been thinking about doing so anyway and now with recent problems and the input here I’ll proceed.
For what it’s worth, I was amazed by the huge speed increase and banishing of beachballs I got from my 2011 imac by starting to boot from an ssd connected by firewire 800.
I do install the drivers. But it occurs to me that virtually all of my enclosures are firewire/usb, but I rarely or never use the usb, so I doubt that I tested them all that way. Yet another project to add to the list…
I found that for the most part I didn’t need the extension for non-USB connected enclosures. As long as the app doesn’t say “Unsupported” your testing should have bee thorough.
