After I rebuilt the mailbox the mail has since stayed in date order, but a bit odd this should be needed after upgrading to Sequoia. Things like that have happened in the past too though, so. Beachball in Contacts I had just 10 minutes ago last time … it is not going away. When I get around to it I will see if I can export everything and import it to a new user’s Contacts, export it from there, clean everything in my Contacts and import it again there, but I am not feeling too optimistic about it helping.
You can turn off the new tiling dragging features in the Desktop & Dock section of System Settings:
If you’re talking about the pop-up that appears when you hover over the green button in the top left of a window, I’m not aware that there’s any way to disable this, but it’s not new in Sequoia. It’s been in MacOS for several versions now, but didn’t have the tiling options previously.
You don’t need to find a place to click to get rid of it, you can simply click on whatever it was you were moving the cursor to (e.g. the Apple menu or the application window). The pop-up will disappear and the menu will open, no extra clicks needed.
Hmm doesn’t seem that fast to me. Google and MS have had AI; Apple is playing catchup. And Apple spent a decade trying to make Siri smarter before this.
A matter of perception no doubt; but to me, it feels like modern technology is racing ahead at breakneck speed for no good reason. ![]()
Well, welcome to my head-spinning career :-) It’s an arms race, for one thing. It’s also both a blessing and a curse: adding great value, but also complexity and disruption.
It’s an arms race for one reason only: the unbridled greed that obsessively fuels almost every business decision in this crazy world. Technological innovation certainly does have the potential to add great value to our lives, but I seriously doubt that we as a species have the wisdom to wield such power responsibly. If we do, we’re certainly not showing it! If even a small fraction of the daily headlines concerning the business world’s shocking lack of integrity are true, the human race is in for a very bumpy ride indeed.
Soooo, now that Sequoia’s been out for a few weeks, what are people’s experiences with regards reliability? If it’s ‘lacklustre’ it suggests to me it might have fewer issues than some recent releases.
I have installed it onto a spare machine but don’t really use it enough to gauge it’s stability. I’d actually like to update and try the Password app.
I’ve been using it since the day after its release and haven’t had any issues. iPhone mirroring has been a huge productivity boost for me, so it’s not been lacklustre from my perspective. And overall there are a number of nice little improvements. It’s the kind of release I like – one or two significant new features along with loads of small things that are better. I’m uninterested in the AI things at the moment, so the lack of them is irrelevant to me.
It’s been super-stable for me since installing a few weeks ago on my MBA. I’ll note that I don’t use a lot of third party utilities, like clipboard managers, etc. FWIW I am back to using Stage Manager because it runs better than it did on Sonoma (my issue on Sonoma was that the key combo to cycle between windows in an app, Cmd-`, would not return to the first window when you got to the last window in Stage Manager, but it worked fine with Stage Manager turned off - that’s fixed on Sequoia.)
Thank you, I hadn’t discovered it would go away if I ignored it. But I’ve never seen it before Sequoia.
Out of curiosity, I tried the Passwords.app today. Exported passwords from 1PW and imported. Was told that several dozen had not been imported as they already existed (I assume it harvested them from saved passwords in Safari?) So I deleted all the passwords in the app and re-imported, but there were still some holdouts that were not imported as they already existed, and I’m not sure why. No passkeys were imported, but this might be because 1PW doesn’t include them in an export to .csv. I think I will continue to use 1PW, as it’s nice that it also holds secure notes and software licenses. But Passwords.app might do for my wife, who has refused to use 1PW (and for all I know, manages by using the same password everywhere.
For context of my experience, I do use quite a lot of third party utilities and it hasn’t been an issue.
(Here’s my menubar at the moment, though I am overdue a bit of a cleanup!)
For me, another stable release with only minor issues: 1) As usual, Apple gave me a fresh httpd.conf file, which I had to replace from my standby I keep just for this reason (amusing to look in the /etc/apache2 directory and see now six versions of the file from the last six major OS releases); 2) My menu bar doesn’t look the same, but I can’t put my finger on what changed. I run in Dark mode, and I have Reduce Transparency on. I now have a plain black menu bar with white menu names and icons. Pretty sure it didn’t used to be black…but can’t say for sure what it was.
I’ve run into a handful of issues, but only one has been a daily frustration: Safari reliability. Even with all Safari extensions disabled and after drastically reducing the number of open tabs, I run into “NSURLErrorDomain” errors that prevent me from opening new tabs. The problem usually goes away after quitting and restarting Safari. I also have problems viewing the content of Outlook.com messages in Safari, i.e. the message list and other parts of the Outlook.com interface are fine, but the message content frequently won’t display. If I try to reload the page, the reload fails with an Outlook application error. This happens at least once a day.
In Sequoia, the Amazon Music app seems to have lost its ability to export music to a local Apple Music/iTunes library. This happens even though I’ve granted it access to the local library and given it full disk access. (I can work around the problem by manually downloading Amazon Music songs to my Mac and then manually importing them into Apple Music, but it is a significantly more laborious process than just clicking on a single “Export to iTunes” command.)
I’m still getting my share of annoying permissions prompts for various apps, and I’ve occasionally clicked too quickly on the wrong button, leaving me to fumble around to figure out how to correct a mis-applied permission.
Also, if you use Zoom, Teams, or other screen sharing apps, you’ll probably need to re-apply the various permissions needed to share your screen or files if you use those features.
Altogether, I’m really starting to reconsider how I use computers. I’ve always liked trying and using a lot of different apps, but it seems that the OS-driven friction of using and maintaining them keeps increasing over time. I’m seriously considering drastically reducing the number and kinds of apps I use and just focusing on the absolute essentials. It’s just not fun anymore for me.
The developer of well known accounting software “MacKonto” in Berlin/Germany has a big fat warning about SEQUOIA here: Sequoia Problems
(use Safari’s translate feature or deepl.com if your German is a bit rusty)
Holy smoke, “data loss”! No thanks! Call me when it’s fixed!!
Thanks for sharing!
I see that I am still being offered 15.0 in the software update part of System Settings, even though it is already installed.
Addendum: I clicked on details and it is actually 15.0.1. Will install and see if it solves the Firefox wretchedness.
And it worked! Firefox is back to its usual happy self, with all of the network access issues gone. I have heard that other browsers, even Safari, have been affected by this, so it seemed likely it was the 15.0 update itself causing it.
The downside of being the tech guru in one’s family (applies regardless of gender).
My spouse did, in fact, use one of three passwords on nearly every account she ever set up. She would ask me occasionally to “fix something” and it got to the point where I did not bother asking for a password.
She has cared much more about it in the last 10 years, but was indifferent to 1PW. At various times I’ve purchased family licenses for Path Finder, Dropbox, Evernote, and 1PW. The way her mind works, she does not see any advantage to a shared app when she can find a way to move or store or recall things one piece at a time. Plus, those three passwords.
For some of our home tech, which we do share, she was in the habit of asking me for passwords. I have over a thousand stored in 1PW, though some of those are other bits of information like drivers licenses and passports. I would end up sharing the particular record with her in Messages, which 1PW will do but does so in plaintext with a lot of warnings. It did not feel right.
Finally, in 1PW 8, I reluctantly moved all my password records out of Dropbox and into the supported 1PW cloud. I also helped her set up the individual 1PW account she is entitled to, and showed her how password records could be private or shared. It’s set up on all her devices, as my own respective account is on my devices.
Now, if she asks for a password, I can say “Just a moment,” move the record in my account from private to shared, and then say, “It’s in your 1PW app.” This is much easier and a better use of our time than going through all the records on my account to figure out which ones should be shared. She is confident enough in the process now that she has shared records with me as well.
The big upside is being able to move away from those three easily guessed passwords that are splattered all over the internet; and for records we share, there’s no inconvenience to either of us if we do a password reset.
(Well, that was an off-topic little journey, but I think it connects back to why we won’t be using Apple Passwords any time soon.)
This is the big unknown: what impact this will have on commercial alternatives. I’m all in with a cloud hosted family plan on 1P. I’m in no rush to switch; it would be a pain in the butt. The homework required to avoid risk of data loss or feature regression is not worth my time right now.
On the other hand, something as basic as password management should be a core feature provided by Apple. And not tied to a single browser.
Does Passwords.app work with Chrome?
